Author Topic: WinFBE Suite 1.9.2 (August 25, 2019)  (Read 992 times)
« on: August 25, 2019, 12:34:56 PM »
Version 1.9.2 (August 25, 2019)
- CHANGED: TOO MANY VISUAL DESIGNER CHANGES TO LIST
- Added: Language translation for Brazilian-Portuguese by Marco Pimenta (mvpimenta).
- Added: "Frac", "Date", "Format" keywords to editor syntax highlighting.
- Fixed: Controls property "BorderStyle" not correctly set when dynamically applying WindowStyle and WindowExStyle.
- Fixed: "Visible" property of controls reported the "Enabled" value after control was created.
- Fixed: Label controls could lose their OwnerDraw abilities if visibility was toggled.
- Fixed: Changing selected Build Configuration via F7 dialog did not set the correct build in combobox in the main toolbar.
- Fixed: Random GPF when adding Form files via the "Add Files to Project" menu option.
Download this release from: https://github.com/PaulSquires/WinFBE/releases
Re: WinFBE Suite 1.9.2 (August 25, 2019)
« Reply #1 on: August 25, 2019, 02:25:21 PM »
Thank you, Paul!
« Reply #2 on: August 25, 2019, 05:48:04 PM »
Thanks Clive :)  Still work to be done... treeview, listview, tabcontrol....
The core foundation of the visual designer is looking and performing better all the time which makes adding new controls to the WinFormsX library backend a little bit easier.
Patrick Beyltjens
  • Little Newbie
« Reply #3 on: August 26, 2019, 07:11:08 AM »
Thank you very much
Joerg Buckel
  • FF3 and WinFBE+WinFBX User
« Reply #4 on: September 06, 2019, 01:51:11 PM »
Hello Paul
In the appendix is the updated German language file for the current WinFBE version.
Many thanks for the new version.
Greeting from Germany
Joerg
« Reply #5 on: September 06, 2019, 08:36:57 PM »
Thanks Joerg!
