AfxIFileSaveDialog (trouble setting initial folder on display)
Started by Paul Squires, August 27, 2019, 01:36:50 PM
Hi Jose,
I am still having trouble trying to set the default/initial folder that should display with the SaveAs dialog is shown. It has never worked for me ever since we discussed it way back in 2016:  https://www.planetsquires.com/protect/forum/index.php?topic=3850.msg28382#msg28382
I have posted my test code below in the hopes that you can point out where the problem might be.
Look for this code that I added to your template code.
' *** TRY TO SET THE INITIAL FOLDER WHEN THE SAVE DIALOG DISPLAYS ***
' *** I've tried both SetDefaultFolder and SetFolder and neither seems to work.
' *** This is a follow-up to the discussion here:
' ***      https://www.planetsquires.com/protect/forum/index.php?topic=3850.msg28382#msg28382
' Microsoft Windows
' File: COM_IFileSaveDialog.fbtpl
' Contents: Demonstrates the use of the IFileSaveDialog interface.
' Copyright (c) 2016 José Roca. Freeware. Use at your own risk.
#define UNICODE
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "win/shobjidl.bi"
USING Afx
CONST IDC_OFD = 1001
' // Forward declarations
DECLARE FUNCTION AfxIFileSaveDialog (BYVAL hwndOwner AS HWND, BYVAL pwszFileName AS WSTRING PTR, _
   BYVAL pwszDefExt AS WSTRING PTR, BYVAL sigdnName AS SIGDN = SIGDN_FILESYSPATH) AS WSTRING PTR
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Initialize the COM library
   CoInitialize(NULL)
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "IFileOpenDialog example", @WndProc)
   pWindow.Center
   ' // Add a button
   pWindow.AddControl("Button", , IDC_OFD, "File &Save Dialog", 350, 250, 110, 23)
   ' // Dispatch messages
   ' // Uninitialize the COM library
   CoUninitialize
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_OFD
                  ' // Display the Save File Dialog
                  DIM pwszName AS WSTRING PTR = AfxIFileSaveDialog(hwnd, "test", "bas")
                  ' // Display the selected name
                  IF pwszName THEN
                     MessageBoxW(hwnd, *pwszName, "IFileSaveDialog", MB_OK)
                     CoTaskMemFree(pwszName)
    CASE WM_DESTROY
         ' // Quit the application
         PostQuitMessage(0)
' Displays the File Save Dialog
' The returned pointer must be freed with CoTaskMemFree
   ' // Create an instance of the IFileSaveDialog interface
   DIM hr AS LONG
   DIM psfd AS IFileSaveDialog PTR
   hr = CoCreateInstance(@CLSID_FileSaveDialog, NULL, CLSCTX_INPROC_SERVER, @IID_IFileSaveDialog, @psfd)
   IF psfd = NULL THEN RETURN NULL
   ' // Set the file types
   DIM rgFileTypes(1 TO 3) AS COMDLG_FILTERSPEC
   rgFileTypes(1).pszName = @WSTR("FB code files")
   rgFileTypes(2).pszName = @WSTR("Text files")
   rgFileTypes(3).pszName = @WSTR("All files")
   rgFileTypes(1).pszSpec = @WSTR("*.bas;*.inc;*.bi")
   rgFileTypes(2).pszSpec = @WSTR("*.txt")
   rgFileTypes(3).pszSpec = @WSTR("*.*")
   psfd->lpVtbl->SetFileTypes(psfd, 3, @rgFileTypes(1))
   ' // Set the title of the dialog
   hr = psfd->lpVtbl->SetTitle(psfd, "File Save Dialog")
   ' // Set the file name
   hr = psfd->lpVtbl->SetFileName(psfd, pwszFileName)
   ' // Set the extension
   hr = psfd->lpVtbl->SetDefaultExtension(psfd, pwszDefExt)
   ' // Display the dialog
   hr = psfd->lpVtbl->Show(psfd, hwndOwner)
'   ' // Set the default folder
'   DIM pFolder AS IShellItem PTR
'   SHCreateItemFromParsingName (CURDIR, NULL, @IID_IShellItem, @pFolder)
'   IF pFolder THEN
'      psfd->lpVtbl->SetDefaultFolder(psfd, pFolder)
'      pFolder->lpVtbl->Release(pFolder)
'   END IF
' SetDefaultFolder
' Sets the folder used as a default if there is not a recently used folder value available.
' SetFolder
' Sets a folder that is always selected when the dialog is opened, regardless of previous user action.
   dim as CWSTR wszFolder = "D:\myfolder\test"   ' <-- obviously change this to a valid folder
   SHCreateItemFromParsingName (wszFolder, NULL, @IID_IShellItem, @pFolder)
   IF pFolder THEN
   ' // Get the result
   DIM pItem AS IShellItem PTR
   IF SUCCEEDED(hr) THEN
      hr = psfd->lpVtbl->GetResult(psfd, @pItem)
         hr = pItem->lpVtbl->GetDisplayName(pItem, sigdnName, @pwszName)
         FUNCTION = pwszName
   ' // Cleanup
   IF pItem THEN pItem->lpVtbl->Release(pItem)
   IF psfd THEN psfd->lpVtbl->Release(psfd)
Based on user feedback, Microsoft changed the behavior of the Open and Save dialogs to always remember the last folder used. SetDefaultFolder only sets the folder used as a default if there is not a recently used folder value available. SetFolder should work, but id does not.
With the old GetOpenFileName and GetSaveFileName they did the same with the initial directory parameter, but at least they provided a workaround consisting in passing the full path in the file name parameter:
DIM wszFile AS WSTRING * 260 = "C:\Programs\Tests\Test.bas" ' or "*.bas" or "*.*"
DIM wszFilter AS WSTRING * 260 = "BAS files (*.BAS)|*.BAS|" & "All Files (*.*)|*.*|"
DIM dwFlags AS DWORD = OFN_EXPLORER OR OFN_FILEMUSTEXIST OR OFN_HIDEREADONLY OR OFN_OVERWRITEPROMPT
DIM cws AS CWSTR = AfxSaveFileDialog(hwnd, "", wszFile, "", wszFilter, "BAS", @dwFlags)
IF LEN(cws) THEN MessageBoxW(hwnd, cws, "File", MB_OK)
Found the solution:
Move:
After
   dim as CWSTR wszFolder = "C:\myfolder\test"   ' <-- obviously change this to a valid folder
   IF pFolder THEN
That is:
   IF pFolder THEN
Awesome! Yes, that does seem to work perfectly! Thanks a million - that problem was driving me crazy for a long time.
It's amazing how this one small code fix has made me so happy :) :) :)
Small change, but very important. The call to the Show method must be the last because, otherwise, the call to SetFolder isn't executed until the dialog is closed.
I have uploaded modified templates to GitHub.
Yes, in hindsight it all makes perfect sense that the parameters should be set before displaying the dialog. I don't know how much I looked at that code over that past months and such an easy fix didn't click in for me. I was so fixated on looking at the SetFolder/SetDefaultFolder and thinking that I wasn't setting the IShellItem correctly (even though it did return SUCCESS result code). Oh well, happy it is now working. I will ensure that WinFBX and all the samples and templates are updated for the next WinFBE release.
