Pages: [1] 2 3
Author Topic: find and replace  (Read 4501 times)
find and replace
« on: September 28, 2019, 09:25:04 AM »
Not sure if there is a simple solution, but if you have, say, characters such as  'xs.text' in your code, and you need to replace it with 'form1.xs.text' then if you search for 'xs' and replace with 'form1.xs' it goes on, and on and on. :D
Came across this in converting a c# program to fb, not sure if discussing how to do that somewhere?
Re: find and replace
« Reply #1 on: September 29, 2019, 01:53:23 PM »
Has folding been completely abandoned in winfbe editor? If not, remind me if/how to create fold points (I know it used to be on sub/end sub, etc., and that it wasn't high priority).
Re: find and replace - F8
« Reply #2 on: September 29, 2019, 02:48:10 PM »
Hi Ray,
Have a look at Menu item View/F8. I don't think Folding is quite ready for prime time. If I use folding too many times it stops working. Also, I don't use fold, but I can see its advantages.
« Reply #3 on: September 29, 2019, 07:58:49 PM »
Hi Clive, none of it works for me. From a previous thread iirc, it was a bit irregular. If I try to fold anything it stays as it is. It's not a deal breaker, but it would have been handy, to save my rsi with trackball. Does the key words, function, end, etc have to be in a specific column, or can you add fold points where you wish.
« Reply #4 on: September 29, 2019, 09:04:30 PM »
BTW I'm using WinFBE 1.9.2.
« Reply #5 on: September 29, 2019, 09:09:22 PM »
Folding is likely a work-in-progress.
« Reply #6 on: September 29, 2019, 09:14:14 PM »
Folding is a pain in the butt because the logic is built directly into the scintilla editing dll and is written in C++. I have to modify that source and then re-compile the 32 and 64 bit dll's. I don't love folding that much!  hahaha
BTW, you have to ensure that the Folding Margin is enabled in order to use folding.
Environment Options... Code Editor... Show fold margin
« Last Edit: September 29, 2019, 09:19:57 PM by Paul Squires »
« Reply #7 on: September 29, 2019, 09:44:43 PM »
I never use it. Neither autocomplete nor codetips. I code faster without these gimmicks.
« Reply #8 on: September 30, 2019, 07:51:24 AM »
Thanks, I'd forgot you had to set the fold margin. As long as it doesn't lose code when folding/unfolding, it'll do. I find it useful some times, but not a major issue. Maybe the menu item could be greyed out if folding not enabled?
« Reply #9 on: September 30, 2019, 01:51:47 PM »
Still relating to the c# conversion, the nuts and bolts are working fine, but I was dreading the graphics, however for this particular program, it is merely plotting lines between a list of xy coordinates. I found Jose's code
' Microsoft Windows
' File: DrawLine.bas
' Contents: GDI+ - DrawLine example
' Copyright (c) 2017 José Roca. Freeware. Use at your own risk.
#define UNICODE
#INCLUDE ONCE "Afx/CGdiPlus/CGdiPlus.inc"
#INCLUDE ONCE "Afx/CGraphCtx.inc"
USING Afx
CONST IDC_GRCTX = 1001
' // Forward declaration
' The following example draws a line.
SUB Example_DrawLine (BYVAL hdc AS HDC)
   DIM graphics AS CGpGraphics = hdc
   ' // Get the DPI scaling ratios
   DIM rxRatio AS SINGLE = graphics.GetDpiX / 96
   DIM ryRatio AS SINGLE = graphics.GetDpiY / 96
   ' // Set the scale transform
   graphics.ScaleTransform(rxRatio, ryRatio)
   ' // Draw the line
   DIM blackPen AS CGpPen = CGpPen(GDIP_ARGB(255, 0, 0, 0), 3)
   graphics.DrawLine(@blackPen, 100.0, 100.0, 500.0, 100.0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "GDI+ DrawLine", @WndProc)
   ' // Change the window style
   pWindow.WindowStyle = WS_OVERLAPPED OR WS_CAPTION OR WS_SYSMENU
   ' // Size it by setting the wanted width and height of its client area
   pWindow.SetClientSize(600, 250)
   ' // Center the window
   pWindow.Center
   ' // Add a graphic control
   pGraphCtx.Clear BGR(255, 255, 255)
   ' // Get the memory device context of the graphic control
   DIM hdc AS HDC = pGraphCtx.GetMemDc
   ' // Draw the graphics
   Example_DrawLine(hdc)
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
    CASE WM_DESTROY
         PostQuitMessage(0)
and it works fine, and thanks to the comments, I more or less understand what each line is for. However, I am struggling in merging it with my existing code, which is based on Paul's Winfbe form designer, so much of the form information is hidden. It would help me, if someone more knowledgeable (most likely that's all of you) could use the graphics designer, create a form therein with a button, to generate one of Jose's graphic forms with a line on it, e.g. interface the drawline.bas code with that produced by the winfbe graphics designer.
Ray
« Reply #10 on: September 30, 2019, 03:27:31 PM »
I too would like to know how to do that as I very much want to place a James Klutho GRID onto a WinFBE form.
« Reply #11 on: September 30, 2019, 07:23:55 PM »
Here you go.... :-)
Create a Project and a main form called frmMain.
The example uses GDI+ so that will take some time for you to learn but it is a little better than regular GDI.
Application.Run(frmMain)
dim shared pGraphCtx AS CGraphCtx ptr
const IDC_GRCTX = 2000
   ' // Draw the line
   pGraphCtx = new CGraphCtx( sender.pWindow, _
                              IDC_GRCTX, "", _
                              0, 0, _
                              sender.ClientSize.Width, _
                              sender.ClientSize.Height)
   pGraphCtx->Clear BGR(255, 255, 255)
   DIM hdc AS HDC = pGraphCtx->GetMemDc
   function = 0
Function frmMain_FormClosed( ByRef sender As wfxForm, ByRef e As EventArgs ) As LRESULT
   if pGraphCtx then Delete pGraphCtx
   Function = 0
« Reply #12 on: September 30, 2019, 07:33:07 PM »
thanks, I'll let you know.
Not working for me, it opens the form, but no graphics drawing on it, Also, altering the values in  pGraphCtx->Clear BGR(255, 255, 255) does not change the background colour, so I guess the graphics is not being set up. Also trying to use console printing for debugging does not seem to show either., maybe the graphics is overwriting that? I've tried both 32 bit and 64 bit versions of winfbe. If it works for you, then maybe the default window properties are different.
« Last Edit: September 30, 2019, 08:44:16 PM by raymw »
« Reply #13 on: October 01, 2019, 07:36:30 AM »
Clive,
 Can you try Paul's code above, see if it works for you. Thanks
Ray
(anyone else, join in, of course)
( will the new version suite winfbe 1.93 (just released) solve it, I'm running 1.92)
« Last Edit: October 01, 2019, 07:40:46 AM by raymw »
« Reply #14 on: October 01, 2019, 12:01:03 PM »
I had no luck last night, Ray, I'll try again this morning.
Pages: [1] 2 3
