Author Topic: force quit firefly program  (Read 2534 times)
Shawn Anderson
« on: October 11, 2019, 04:31:47 PM »
How can I programmatically quit a FF program?
« Last Edit: October 11, 2019, 04:41:53 PM by Shawn Anderson »
Re: force quit firefly program
« Reply #1 on: October 11, 2019, 06:42:59 PM »
Hi Shawn,
FF_CloseForm( HWND_MyForm, 0 ) is the built-in FF routine that when called with the projects startup form as its first parameter will shut down the app. I use MyForm_WM_DESTROY function to do some tidying up before the app is shut down. The second parameter is the FF_CloseForm return value.
A less elegant way is to call END which doesn't leave you much except END's return value after the app immediately shuts down.
DestroyWindow HWND_MyForm is not recommended.
I hope this helps.
Shawn Anderson
« Reply #2 on: October 14, 2019, 12:51:49 PM »
perfect, thanks
