Author Topic: WinFBX Sample_Projects (fixed files)  (Read 2074 times)
« on: November 01, 2019, 01:52:07 PM »
Hi Jose,
The *.wfbe project files in the Sample_Projects folder of WinFBX were incorrect. I took some time and went through each folder and created new project files and deleted a few extra unneeded files. I have attached the updated files to this post for you to include in your WinFBX distribution.
Paul
Re: WinFBX Sample_Projects (fixed files)
« Reply #1 on: November 01, 2019, 03:04:16 PM »
Thanks. I have updated the .wbfe files in my Git repository.
