Author Topic: error 42: Variable not declared  (Read 909 times)
jermy
  • Little Newbie
« on: November 11, 2019, 02:10:02 PM »
Why i cant use QueryFullProcessImageName?
Main.bas
#Include Once "windows.bi"
#Include Once "win/winbase.bi"
#Include Once "win/wincrypt.bi"
#Include Once "Form1.inc"
Application.Run(Form1)
Form1.inc
Function Form1_Button1_Click( ByRef sender As wfxButton, ByRef e As EventArgs ) As LRESULT
Dim Ret as WINBOOL
    Ret = FindClose(0)                                                   'winbase.bi
    Ret = IsDebuggerPresent                                          'winbase.bi
   Ret = QueryFullProcessImageName(0, 0, 0, 0)            'winbase.bi
   print AfxGetWinErrMsg(GetLastError)
   Function = 0
The compiler says 'error 42: Variable not declared , QueryFullProcessImageName ...
I forgot to add something?.
Re: error 42: Variable not declared
« Reply #1 on: November 11, 2019, 02:54:52 PM »
Yes. Put
#define _WIN32_WINNT &h0602
before the includes.
jermy
  • Little Newbie
« Reply #2 on: November 11, 2019, 03:02:38 PM »
that works, why didn't I think about that myself?
Tnx Josť
