Author Topic: WinFBE Suite 1.9.9 (November 17, 2019)  (Read 1848 times)
« on: November 17, 2019, 07:45:36 PM »
Version 1.9.9 (November 17, 2019)
- Added: New method Form.ShowChild allows displaying a Form as a child (WS_CHILD). This allows forms to act like child panel controls.
- Added: ListView DoubleClick, RightClick events.
- Added: ListView Click event will now also fire if ENTER is pressed on a ListView line.
- Changed: ListView Columns.Add now only requires Text parameter with Width (default 100 pixels) and Alignment (TextAlignment.Left) being optional.
- Fixed: ListView Click event was not returning correct e.ListViewRow, e.ListViewColumn values.
- Fixed: When items are insert/remove from ListView/ListBox/ComboBox then their Index properties are now updated to accurately reflect their new position within the collections.
- Fixed: Bug in Replace All whereby start search position was incremented by length of the find phrase rather than the replace phrase.
- Fixed: Compile would fail if RichEdit exists in a project but no TextBoxes also exist in the project.
Re: WinFBE Suite 1.9.9 (November 17, 2019)
« Reply #1 on: November 18, 2019, 02:43:39 PM »
For the next update I have added the ability to invoke sorting (ascending or descending) of the ListView items based on a specified SubItem/Column index.
This will allow you to do things like respond to the user clicking on a column header to toggle sorting that column ascending or descending. The internal code uses a Shell Sort that is decently fast for most purposes.
Example:
Function frmEmpPicker_lvEmployees_ColumnClick( ByRef sender As wfxListView, ByRef e As EventArgs ) As LRESULT
   ' Sort the ListView based on the column that is clicked. Toggle Ascending
   ' and Descending sorting if the same column is clicked.
   ' Don't sort on the first subitem as it is only the line numbers
   if e.ListViewColumn = 0 then exit function
   ' Toggle the sort direction if the same column has been subsequently clicked on
   if gSortColumn = e.ListViewColumn then
      gSortAscend = not gSortAscend
   frmEmpPicker.lvEmployees.BeginUpdate
   frmEmpPicker.lvEmployees.Items.SortByColumn( gSortColumn, gSortAscend )
   ' Update the individual row numbers. This is not necessary but I had a column at
   ' position 0 that simply displayed the row number (like Excel or other grids).
   dim as long nCount = frmEmpPicker.lvEmployees.Items.Count
   for i as long = 0 to nCount - 1
      frmEmpPicker.lvEmployees.Item(i).SubItem(0).Text = wstr(i+1)
   next
   frmEmpPicker.lvEmployees.EndUpdate
   Function = 0
« Reply #2 on: November 18, 2019, 03:29:33 PM »
For the next update:
- Added: ListView Click event now sets e.KeyChar = 13, e.KeyCode = VK_RETURN, whenever ENTER is pressed on a selected row.
Re: WinFBE Suite 1.9.9 (November 17, 2019) - Sorting
« Reply #3 on: November 18, 2019, 04:32:20 PM »
Usefull feature, Paul, will sorting work on dates?
To avoid confusion, my dates are always "dd-mmm-yyyy" as in 18-Nov-2019. Smallest to biggest with a 2 digit day, an alpha month and 4 digit year. I use a number of date handling routines to modify date such as those returned from a calendar control.
    Dim strut1 as SYSTEMTIME '' Structure
    MonthCal_GetCurSel( HWND_FRMMAIN_MONTHCALENDAR1 , @strut1 )
    Dim as Long a = DateSerial( strut1.wYear, strut1.wMonth, strut1.wDay )
    ? Format( a, "dd-mmm-yyyy" )
« Reply #4 on: November 18, 2019, 06:40:08 PM »
Sorting just works on the raw text (case insensitive). It doesn't know that the data is text, number, date, etc... I don't want to implement a callback functionality so if you must show your dates in your dd-mmm-yyyy format then you might also want to create a hidden column containing YYYYMMDD and sort that column in response to clicks on the dd-mmm-yyyy column,
« Reply #5 on: November 18, 2019, 07:09:37 PM »
The date format is just a holdover from ages ago when we couldn't allow a user to confuse days and months and years and we only had 16 characters to display it plus the time. Not required any more.
YYYYMMDD will work just fine, thanks.
« Reply #6 on: November 18, 2019, 09:51:46 PM »
No problem. In my applications I display the dates as YYYY-MM-DD as it is the least confusing format and easiest to sort by, etc.
WinFBE Suite 1.9.9 - Form Line Numbers
« Reply #7 on: November 19, 2019, 01:48:58 PM »
Hi Paul, __LINE__ is reporting the file's line number in forms, not the editor's line number. I thought you made mention of this ages ago but I couldn't find the post.
__LINE__ works correctly in other files.
If I need the number the form file can be kept open in NotePad++ and call GoTo line number, easy peasy.
« Last Edit: November 19, 2019, 01:54:37 PM by SeaVipe »
« Reply #8 on: November 21, 2019, 10:54:24 AM »
The Form`s configuration data is stored in the Form file prior to the regular code of the form. This means that whenever an error occurs I need to offset the reported compiler error line number by the number of configuration lines that exists in the form file. It is a bit of a pain but it does allow me to keep everything within one file rather than to have the form`s code in one file and the form`s configuration data in a separate file.
« Reply #9 on: November 21, 2019, 10:56:32 AM »
See attached screenshot of how I am modifying the "New Project" dialog. It will allow you to specify a template to use when the project is initially created. This will be in the next release.
Line Numbers
« Reply #10 on: November 21, 2019, 01:27:57 PM »
This is so not a big deal but, could the form's configuration data be placed after the regular code? Or is there a way that the last form configuration line number could be an internal offset?
