Catch ENTER key on controls
Started by Petrus Vorster, December 08, 2019, 01:32:15 PM
Good Day
How do i catch an ENTER key on a Textbox and Buttons that usually don't support it?
I have users that say its faster in typing if they just type and Enter instead of my approach of Tab on text boxes and Space key on buttons.
My Keydown events attempts had caused some undesirable and interesting outcomes.
(This is still in Powerbasic)
Regards, PEter
-Regards
Peter
Ian Vincent
Petrus,
One way is to put this in the KeyUp section:
'*****Put in the KeyUp event ************
Local aa As String
If nVirtKey=13 Then
    aa=FF_Control_GetText( hWndControl)
    'do what you want with aa
    FF_Control_SetFocus( HWND_RECORDING_TEXT2 )
(there might be better ways)
Ian
Thanks Ian
I will give it a shot.
Personally i feel people must learn to use both hands when typing.
There are some that still comes from the DOS days and just captures with the one hand.
Regards,
Peter
-Regards
Peter
Thanks Ian
went this way:
Select Case nVirtkey
Case 13
  FF_Control_SetFocus(HWND_FORM3_TEXT5)
Works, perfectly, Thanks!
-Peter
-Regards
Peter
Controls that does NOT have a key-up event ( I have a firetextbox still in use for the currency control) or a Image button...
How do i go that route?
Sorry for all the questions, I never anticipated a request like that for enter keys.
-Peter
-Regards
Peter
Klaas Holland
When you want the Enter-Key to act as the Tab-Key, you change the Pumphook to:
For FF-PowerBasic the code is:
Function FF_PUMPHOOK( Msg As tagMsg ) As Long
   ' If this function returns FALSE (zero) then the processing of the regular
   ' FireFly message pump will continue. Returning TRUE (non-zero) will bypass the regular message pump.
   Function = %FALSE    'return %TRUE if you need to bypass the FireFly message pump
   ' If you are dealing with a 'normal' OCX control then the following code will
   ' allow the message to be forwarded to the OCX.
   #If %USEOLECON = 1
      Function = OC_ForwardMessage( GetFocus(), Msg)
   #EndIf
'    Filter the ENTER key For the command buttons
   Select Case Msg.Message
      Case %WM_KEYDOWN
         Local hFocus    As Dword
         Local idControl As Long
         hFocus      = GetFocus()
         If Msg.wParam = %VK_RETURN Then
            ' Only handle the ENTER key for the CommandButtons that we are interested in.
            Static zClass As Asciiz * 50
            GetClassName Msg.hWnd, zClass, SizeOf(zClass)
            If UCase$(zClass) = "BUTTON" Then
                idControl = GetWindowLong( hFocus, %GWL_ID )
                SendMessage GetParent(hFocus), %WM_COMMAND, Mak( Long, idControl, %BN_CLICKED), hFocus
                Msg.Message = %WM_NULL
            Else
                SetFocus GetNextDlgTabItem (GetActiveWindow, GetFocus, 0)
And for FF-FreeBasic the code is:
Function FF_PUMPHOOK( Msg as tagMsg ) as Long
   Function = False    'return TRUE if you need to bypass the FireFly message pump
      Case WM_KEYDOWN
         Dim hFocus    as HWnd
         Dim idControl as Long
         hFocus     =  GetFocus()
         If Msg.wParam = VK_Return Then
            Static zClass as ZString * 50
            GetClassName Msg.HWnd, zClass, SizeOf(zClass)
                idControl = GetWindowLong( hFocus, GWL_ID )
                SendMessage GetParent(hFocus), WM_COMMAND, MAKELONG(idControl, BN_CLICKED), Cast(WPARAM , hFocus)
                Msg.Message = WM_NULL
            Else
HI Klaas!
Nice to hear from you!
PS, your company website is awesome. Very professional!!!
Thank you for this, i will go and try it immediately!!!
Regards,
Peter
-Regards
Peter
