WinFBE Suite 2.0.2 (December 16, 2019)
Started by Paul Squires, December 16, 2019, 05:23:23 PM
Version 2.0.2 (December 16, 2019)
- Fixed: ToolTip needed to have at least 1 character set at design time in order for ToolTip to display at runtime because the hWndToolTip would not be created.
- Fixed: ListBox code regression in wfxApplication.inc WM_ERASEBKGND handler that caused excessive visual flicker (ControlType.ListBox was accidently set to ControlType.ListView).
- Fixed: ListView now draws significantly faster becase only affected changed visible line items invoke a redraw of the ListView. Uses ListView_IsItemVisible to determine if item is visible.
#1
Thanks for the fixes, now much better.
