Author Topic: WinFBE - 2.0.2 - Code Editor Text Colour  (Read 175 times)
« on: January 07, 2020, 12:43:44 PM »
In the following line of code, all colour from the # to the right is colour as TEXT. Everything to the left of the # (excluding the #) is correctly coloured as per the Colors And Fonts settings. This colouring only affects the subject line.
Dim as Long o = Open( This.jdb_file_name For Random Access Read as #ff Len = Sizeof( js ) )
Re: WinFBE - 2.0.2 - Code Editor Text Colour
« Reply #1 on: January 07, 2020, 01:35:01 PM »
Thanks Clive - yes, I've seen similar situations like that with the # hash symbol. It is related to the internal language definition used in my version of the Scintilla editing control. Some day I need to better learn C++ and understand the code that I am using for that language parser.
Re: WinFBE - 2.0.2 - StatusBar - Observations
« Reply #2 on: January 07, 2020, 04:13:31 PM »
Thanks, Paul.
- Another oddity, my app has a sub form with a statusbar control. At run time, the first time the form is shown the statusbar works as designed, the second and subsequent times the form is opened the statusbar is hidden. A restart of the app restores the sub form's statusbar for its one and only appearance. .Show and .Refresh have no visible effect.
- When the sub form is Closed, the parent form's StatusBar is momentarily hidden and then shown (with or without updates to Panel().Text). (This also happens to a Calendar control on the parent form and simultaneously to the Calendar control in the WinFBE Visual Designer)
- The StatusBar font cannot be changed, the following code has no effect:
'' Example: (Doesn't appear to be enabled, but compiles OK.)
frmMain.StatusBar.Font = New wfxFont("Consolas", 10, FontStyles.Bold, FontCharset.Ansi)
- StatusBarPanelBorderStyle: Raised and Sunken both appear as Flat; None works.
« Reply #3 on: January 13, 2020, 03:22:04 PM »
This is now (finally) fixed. The same problem would happen with MainMenus and ToolBars.
« Reply #4 on: January 13, 2020, 03:43:05 PM »
Thanks, Paul!
« Reply #5 on: January 14, 2020, 12:53:27 PM »
This is now fixed and will be in the 2.0.3 update.
« Reply #6 on: January 14, 2020, 12:59:12 PM »
Based on my tests, it appears that sunken and raised only have effect if the Windows Theme support is disabled for the application. Obviously, I will not be removing (or allow to be removed) theme support from WinFBE applications so I will remove these panel type options from the WinFBE designer.
