Author Topic: Get local IP address  (Read 1365 times)
« on: February 24, 2020, 02:45:33 PM »
Petrus Vorster posted a question that he has deleted while I was doing some research. It was about retrieving the local IP address of a computer.
In FreeBasic, you can do this:
DIM wsad AS WSAData
IF WSAStartup(&h202, @wsad) = 0 THEN
   DIM hostname AS ZSTRING * 256
   IF gethostname(hostname, SIZEOF(hostname)) = 0 THEN
      DIM pHostent AS HOSTENT PTR = gethostbyname(hostname)
      IF pHostent THEN
         DIM IPbuffer AS ZSTRING PTR = inet_ntoa(*CAST(IN_ADDR PTR, pHostent->h_addr_list[0]))
         print "Local IP host address: "; *IPbuffer
   WSACleanUp
« Last Edit: February 24, 2020, 02:50:46 PM by Josť Roca »
Pierre Bellisle
Re: Get local IP address
« Reply #1 on: February 25, 2020, 02:33:58 AM »
Hola Josť,
Also, this might be of some value, since GetHostByName is deprecated and MS insist on using GetAddrInfo...
#Define JumpCompiler "<D:\Free\64\fbc.exe>"
#Define JumpCompilerCmd "<-s gui -w pedantic "D:\Free\bas\~~Default.rc">"
#define UniCode
#Include Once "windows.bi"
#Include Once "win\winsock2.bi"
#Include Once "win\ws2tcpip.bi"
 DIM wsad AS WSAData
 IF WSAStartup(&h202, @wsad) = ERROR_SUCCESS THEN
   DIM zHostName AS ZSTRING * 256
   IF gethostname(zHostName, SIZEOF(zHostName)) = ERROR_SUCCESS THEN
     'zHostName = "localhost"     'Will return 127.0.0.1
     'zHostName = "microsoft.com" 'In a loop, will return 40.113.200.201, 104.215.148.63, 13.77.161.179, 40.76.4.15, 40.112.72.205
     DIM pAddressInfoList AS ADDRINFOW POINTER
     DIM AddressInfoHint  AS ADDRINFOW
     AddressInfoHint.ai_family   = AF_INET
     AddressInfoHint.ai_socktype = SOCK_STREAM
     AddressInfoHint.ai_protocol = IPPROTO_TCP
     IF GetAddrInfo(zHostName, "http", @AddressInfoHint, @pAddressInfoList) = ERROR_SUCCESS THEN
       DO 'REM to get only the first assigned ip
         DIM pSockAddrIn AS PSOCKADDR_IN = Cast(PSOCKADDR_IN, pAddressInfoList->ai_addr)
         DIM IPbuffer AS ZSTRING PTR = inet_ntoa(*CAST(IN_ADDR POINTER, @pSockAddrIn->sin_addr.s_addr))
         MessageBox(HWND_DESKTOP, "Local IP host address: " & *IPbuffer, zHostName, MB_OK OR MB_TOPMOST)
         IF pAddressInfoList->ai_next = 0 THEN EXIT DO 'REM to get only the first assigned ip
         pAddressInfoList = Cast(ADDRINFOW POINTER, pAddressInfoList->ai_next) 'REM to get only the first assigned ip
       LOOP 'REM to get only the first assigned ip
       FreeAddrInfo(pAddressInfoList) 'Free address list memory
     'MS: GetHostByName is deprecated. Developers creating Windows Sockets 2 applications
     '    are urged to use the GetAddrInfo function instead of GetHostByName.
     'DIM pHostent AS HOSTENT PTR = GetHostByName(zHostName)
     'IF pHostent THEN
     '  DIM IPbuffer AS ZSTRING PTR = inet_ntoa(*CAST(IN_ADDR POINTER, pHostent->h_addr_list[0]))
     '  MessageBox(HWND_DESKTOP, "Local IP host address: " & *IPbuffer, zHostName, MB_OK OR MB_TOPMOST)
     'END IF
   WSACleanUp()
Pierre Bellisle
« Reply #2 on: March 16, 2020, 02:52:11 PM »
A note to say that I'm not usually really worried about api going removed.
A lot are deprecated, even since the end of the 90s and are still alive.
I think that it is Raymond Chen who said that Microsoft is really conservative on this aspect,
because, from experience, api removal produce too many complaints around the globe...
This said, this is the rare use of imperative words Microsoft used made me a little afraid.
> Developers creating Windows Sockets 2 applications are urged to use the getaddrinfo function instead of gethostbyname.
« Reply #3 on: March 16, 2020, 03:15:39 PM »
Hi Guys
Yes, I actually found the answer in some older files i had, felts stupid, and removed the post.
Thank you for always coming up with help and advice!
-regards Peter
