Author Topic: WinFBE Suite 2.0.7 (March 2, 2020)  (Read 201 times)
« on: March 02, 2020, 05:54:52 PM »
Version 2.0.7 (March 2, 2020)
- Added: Checks to detect multiple calls to the Application.Run function for visual designer projects. Warning shown on compile.
- Added: If Application.Run already exists in visual designer project then any newly created forms will have that call automatically commented out in the code editor.
- Added: New User Tool action option: "Invoke immediately after WinFBE starts". This will run (or show) the user tool immediately after the main WinFBE window is displayed.
- Added: For convenience added POINT variable to the e EventArgs. This is essentially the e.x and e.y window screen positions combined.
- Added: wfxPoint class now has Convert method to transform screen coordinates to client coordinates (instead of having to use MapWindowPoints api).
- Changed: The Explorer pane now uses FullRowSelect style for its TreeView.
- Fixed: Better setting of initial folder for Open / SaveAs when projects are active.
- Fixed: Smoother redrawing of Explorer treeview when large number of files are expanded or collapsed (much more pleasing visual experience).
- Fixed: ProgressBar drawing with Value property now better updates control visually (Windows issue with Themes).
- Fixed: Regression - somehow old corrupted wfbe project files for the Sample_Projects were included in the 2.0.4, 2.0.5 and 2.0.6 releases.
Joerg Buckel
  • FF3 and WinFBE+WinFBX User
Re: WinFBE Suite 2.0.7 (March 2, 2020)
« Reply #1 on: March 09, 2020, 05:58:20 AM »
Hello Paul
I have attached the current German language file.
Greeting from Germany
Joerg
« Reply #2 on: March 09, 2020, 07:56:55 AM »
Thanks Joerg! I really appreciate you providing the new language file.
