Author Topic: WinFBE 2.0.7 - Frame  (Read 165 times)
« on: March 04, 2020, 05:12:02 PM »
Hi Paul, In a new project, there is 1 frame on a form. Modifying the Text property prior to modifying the Form's Text property from Form_Load works but modifying the Frame's Text property a second time, the frame disappears.
If I reverse the order of the 2 calls, frmMain.Text = "Some text" before frmMain.Frame1.Text = "Some text" then the frame will not disappear regardless of where its called from.
Re: WinFBE 2.0.7 - Frame
« Reply #1 on: March 04, 2020, 09:26:52 PM »
Hi Clive, thanks for the report. I am trying to replicate the problem but have not yet been successful. I create a simple new project and added a Frame and a Button. Here is the code but the frame does not disappear. I am using 2.0.6.
   frmMain.Frame1.Text = "Frame new text"
   frmMain.Text = "Form Name modified"
   frmMain.Frame1.Text = "Frame New Load Text"
   Function = 0
   frmMain.Frame1.Text = "FrameText from Button"
   Function = 0
« Reply #2 on: March 05, 2020, 12:59:16 PM »
This hides the frame:
    '' Modifying the form's text here will hide the frame
    frmMain.Text = "FormText from button"
    Function = 0
Reverse the order of the 2 lines of code:
    '' Modifying the form's text here will NOT hide the frame
    Function = 0
Also, I added a second button that does not hide the frame (like the second example code) and when clicked it restores the frame, if hidden, and displays the new text. I'm using WinFBE 2.0.7
« Reply #3 on: March 05, 2020, 01:32:59 PM »
Thanks Clive - yes, I see the problem now using your code. Looks like when I call AfxRedrawWindow in the Text set property of the base wfxControl class that it causes the frame to disappear. If I comment out that function call then the frame does not vanish.
property wfxControl.Text( byref nValue as wstring )
   if this.hWindow then
      AfxSetWindowText(this.hWindow, nValue)
      AfxRedrawWindow(this.hWindow)   '<--- this is causing the frame issue
   _Text = nValue
end property
I might just add a Text property to the wfxForm class in order to override the base wfxControl call. I can't remember why I added AfxRedrawWindow after the call to AfxSetWindowText but I must have done so for a reason....maybe there was another control that needed the window refresh after setting the text. I can't remember at this point.
