Author Topic: Label  (Read 209 times)
Label
« on: March 07, 2020, 05:25:28 PM »
Hi Paul, is there a limit to the number of characters that can be displayed in a label control? To clarify, I appear to have hit a limit of approximately 300 characters.
Re: Label
« Reply #1 on: March 07, 2020, 09:21:34 PM »
Hi Clive, I don't see anything in the code that would limit a Label to the amount of characters that you are seeing. I use CWSTR to hold the text data and that is a dynamic unicode string type. Maybe the display area of your label is not large enough and the text is getting clipped?
Pierre Bellisle
Re: Label
« Reply #2 on: March 07, 2020, 10:42:30 PM »
You might also try to increase the height. You may be a victim of a word-wrap...
Re: Label
« Reply #3 on: March 08, 2020, 02:33:40 PM »
Thanks, Paul and Pierre, Here is the code:
Sub Show_Help()
    'Dim s as String * 500 = " Priority:" + Chr(13,10)
    'Dim s as String = " Priority:" + Chr(13,10)
    'Dim s as WString * 500 = " Priority:" + Chr(13,10)
    Dim s as CWSTR = " Priority:" + Chr(13,10)
    s += Chr(13,10)
    s += " A - Imminent Tasks. Must be completed by Due Date." + Chr(13,10)
    s += " B - Tasks that are weather dependent." + Chr(13,10)
    s += " C - Tasks that must be done but with a changeable Due Date." + Chr(13,10)
    s += " D - Tasks with long-term but still limited time constraints." + Chr(13,10)
    s += " E - Tasks that have no time constraints." + Chr(13,10)
    s += " F - Finished. Completed Tasks."
    frmMain.Label1.Text = s
    Dim as String x = Trim(frmMain.Label1.Text)
    ? Len(Trim(s)), Len(Trim(x))    End Sub
'' ______________________________________________________________________________________
    Show_Help()
    Function = 0
The attached image is the result after Button1.Click. (The console displays the numbers 305 and 305) As you can see, 1/2 of line 'E' and all of line 'F' are missing. This is a new 2.0.7 project with just a Label and a Button.
« Last Edit: March 08, 2020, 02:36:10 PM by SeaVipe »
Re: Label
« Reply #4 on: March 08, 2020, 08:38:36 PM »
Sorry Clive - this is my oversight. The Label is Owner Draw. Prior to outputting the text to the drawing rectangle I was assigning it to a WSTRING * MAX_PATH variable. Obviously using MAX_PATH is not large enough and you see that in your example. I have changed the code to the following and it is now working perfectly.
                     dim as CWSTR wszCaption = AfxGetWindowText( lpdis->hwndItem )
                     DrawText( memDC, wszCaption.sptr, -1, Cast(lpRect, @rcText), lFormat )
I hope to upload a new package tomorrow. I have some help files to write and finish a visual designer sample project.
Re: Label
« Reply #5 on: March 09, 2020, 12:48:29 PM »
