Author Topic: WinFBE - Wish List  (Read 273 times)
WinFBE - Wish List
« on: April 10, 2020, 11:59:28 PM »
Hi Paul, is it possible for the Tool Box to restore its position and size from one session to the next? I keep it fairly large and on a different monitor from WinFBE.
Can the successful compile sound be optional?
Re: WinFBE - Wish List
« Reply #1 on: April 11, 2020, 07:01:20 AM »
Yes and Yes.  :-)
I'll work on getting both of those requests into the next update.
« Reply #2 on: April 11, 2020, 02:11:46 PM »
Thanks, Paul. :0)
« Reply #3 on: April 12, 2020, 11:35:02 AM »
Hi Clive, both of these new feature requests have now been implemented and will be in the 2.1.1 update.
