Author Topic: WinFBE Suite 2.1.6 (May 17, 2020)  (Read 215 times)
« on: May 17, 2020, 12:06:30 PM »
Version 2.1.6 (May 17, 2020)
Editor:
- Fixed: Issue with subs/functions not displaying in Explorer treeview during project loading.
- Fixed: File/Open single source file (non-project related) would not display filename in Explorer treeview.
- Fixed: Leading chr(9) tab characters interfered with triggering Autocomplete for "this." or "this->".
- Fixed: Parser infinite loop when parsing DIM lines with { } variable initializers.
- Fixed: Compiling a visual designer Form file when a project was not active would fail if more than one file was open in the editor at the time of compiling.
- Fixed: A Utf8 to Unicode conversion error when outputting Form code.
- Fixed: Some elements from parsed code would not display in popup AutoComplete selection lists.
- Fixed: Run after Compile would fail if -x command line used specifying a relative path filename.
Visual Designer:
- Fixed: Form would flash on screen even if Visible = False.
Download from:  https://github.com/PaulSquires/WinFBE/releases
ji_vildaasen
  • Little Newbie
Re: WinFBE Suite 2.1.6 (May 17, 2020)
« Reply #1 on: May 21, 2020, 01:28:25 PM »
The small(and unimportant) bug with "Parent" not showing up is still there.
It happens if you copy the code from my post, and paste it in a new file in WinFBE. If you then go to line 52, and type "This." (without any indentation), then "Parent" will show in the list, but if you type "p" then the list will show no matching words. If you first do the same, but add one or more tabs before "This." then "Parent" will work as expected(and keep working even if you delete the text and type "This." without a tab).
This code misses the "w" in "FBImageBox_Parent" when showing autocomplete with "This.Parent." at line 53. I did try to replicate the the error with some test code, but could not replicate it. So there is something with this code that triggers it =)
Also if I type "This." on line 52, the autocompletet list will show "Parent" in the list, but if type "p" then the autocomplete list wont find any matches in the list..
I'm using Tabs, not spaces for indentation.
Type FBImageBox_Options
V_Centered as Boolean
H_Centered as Boolean
end type
type FBImageBox_Parent
hWindow as HWND
w as Long
h as Long
Declare Sub Update()
end type
Type FBImageBox
Options as FBImageBox_Options
Parent as FBImageBox_Parent
x as Long
y as Long
w as long
h as Long
   Scale as Long = 1
Border as long = 0
Border_Col as ulong = 0
Buffer as FB.Image Ptr
TempBuffer as FB.Image Ptr
MaxW as Long = 1000
MaxH as Long = 1000
Declare sub Draw()
Declare sUB Update()
Declare Destructor()
end type
'____________________________________________________________________________________________________________________________________
Sub FBImageBox.Update()
This.Parent.Update
Parent.Update()
This.Parent
If Options.V_Centered then
This.Draw()
Sub FBImageBox.Draw()
PrintMSG "FBImageBox.Draw()"
if Buffer = 0 then exit sub
If TempBuffer = 0 Then TempBuffer = ImageCreate(MaxW, MaxH, 0, 32)
Put TempBuffer, (0, 0), Buffer, Pset
Dim As BITMAPV4HEADER bmi
With BMI
.bV4Size = Len(BITMAPV4HEADER)
.bv4width = TempBuffer->Pitch / 4
.bv4height = -(TempBuffer->Height)
.bv4planes = 1
.bv4bitcount = 32
.bv4v4compression = 0
.bv4sizeimage = ((TempBuffer->Pitch / 4) * TempBuffer->Height) * 4
.bV4RedMask = &h0f00
.bV4GreenMask = &h00f0
.bV4BlueMask = &h000f
.bV4AlphaMask = &hf000
End With
Var hdc = GetDC(Parent.hWindow)
StretchDIBits(hDC, x, y, Buffer->Width, Buffer->Height, 0, 0, Buffer->Width, Buffer->Height, CPtr(Any Ptr, TempBuffer) + SizeOf(FB.Image), CPtr( BITMAPINFO Ptr, @BMI), DIB_RGB_COLORS, SRCCOPY )
DeleteDC(hdc)
Destructor FBImageBox()
PrintMSG "FBImageBox.Destructor()"
   If Buffer <> 0 then ImageDestroy(Buffer)
   Buffer = 0
   If TempBuffer <> 0 then ImageDestroy(TempBuffer)
   TempBuffer = 0
end destructor
Sub FBImageBox_Parent.Update()
w = AfxGetWindowClientWidth( hWindow )
h = AfxGetWindowClientHeight( hWindow )
PrintMSG "FBImageBox_Parent.Update() : w = " & w & ", h = " & h
