Author Topic: center control  (Read 598 times)
James Fuller
center control
« on: June 13, 2020, 08:01:43 AM »
José,
  What is the best way to center a control Vertically or Horizontally on a CWindow?
Does the framework provide such a procedure?
I am experimenting with a CXpButton and the old framework I ported to bc9Basic.
  Thank you and be safe,
James
Re: center control
« Reply #1 on: June 13, 2020, 08:06:04 AM »
Jose's WinFBX library has functions in AfxWin.inc to do this:
' Centers a control horizontally.
' hCtrl = Handle of the control.
PRIVATE SUB AfxCenterControlH (BYVAL hCtrl AS HWND)
' Centers a control vertically
PRIVATE SUB AfxCenterControlV (BYVAL hCtrl AS HWND)
' Centers a window on the screen or over another window.
' It also ensures that the placement is done within the work area.
' Parameters:
' - hwnd = Handle of the window.
' - hwndParent = [optional] Handle of the parent window.
PRIVATE SUB AfxCenterWindow (BYVAL hwnd AS HWND = NULL, BYVAL hwndParent AS HWND = NULL)
Re: center control
« Reply #2 on: June 13, 2020, 08:11:37 AM »
Funny that I wrote AfxCenterControlH and AfxCenterControlV because he asked me to do it :)
See: https://www.planetsquires.com/protect/forum/index.php?topic=3956.msg29555#msg29555
« Last Edit: June 13, 2020, 08:26:16 AM by José Roca »
James Fuller
Re: center control
« Reply #3 on: June 13, 2020, 09:40:37 AM »
Guys,
  I'm lucky I remember what day it is.  A forum post from 4 years ago, not likely  :)
Thank you,
James
James Fuller
Re: center control
« Reply #4 on: June 13, 2020, 10:14:52 AM »
I probably would have found it on my own but I was using the wrong include file that did not have them.
Thanks again
James
