AfxTime
Started by Richard Kelly, June 16, 2020, 08:05:11 PM
Richard Kelly
Using the latest WINFBE version, function AfxTimeZoneBias works as expected and when I use AfxTimeZoneDaylightBias I always get decimal 4294967236 or FFFFFFC4 as the return value.
I see that WORD is defined as uShort and wonder if that could be the source of the issue. -60 is FFC4.
Change
PRIVATE FUNCTION AfxTimeZoneBias () AS DWORD
PRIVATE FUNCTION AfxTimeZoneDaylightBias () AS DWORD
to
PRIVATE FUNCTION AfxTimeZoneBias () AS LONG
PRIVATE FUNCTION AfxTimeZoneDaylightBias () AS LONG
and many thanks for reporting it.
Richard Kelly
Jose...that cleared things up.
Richard Kelly
You have:
AfxTimeZoneDaylightDay
AfxTimeZoneDaylightDayOfWeek
AfxTimeZoneDaylightHour
AfxTimeZoneDaylightMonth
For the transition from Standard to Daylight and I could not find:
AfxTimeZoneStandardDay
AfxTimeZoneStandardDayOfWeek
AfxTimeZoneStandardHour
AfxTimeZoneStandardMonth
for the transition from Daylight to Standard. Per MSDN, when the StandardDate.wMonth = 0, daylight savings is not observed.
#4
' Returns the time zone identifier.
' Return values:
' - TIME_ZONE_ID_UNKNOWN (0)
'     Daylight saving time is not used in the current time zone, because there are no
'     transition dates or automatic adjustment for daylight saving time is disabled.
' - TIME_ZONE_ID_STANDARD (1)
'     The system is operating in the range covered by the StandardDate member of the
'     TIME_ZONE_INFORMATION structure.
' - TIME_ZONE_ID_DAYLIGHT (2)
'     The system is operating in the range covered by the DaylightDate member of the
' If the function fails for other reasons, such as an out of memory error, it returns
' TIME_ZONE_ID_INVALID. To get extended error information, call GetLastError.
PRIVATE FUNCTION AfxTimeZoneId () AS DWORD
   DIM tzi AS TIME_ZONE_INFORMATION
   RETURN GetTimeZoneInformation(@tzi)
' Indicates whether the the system is operating in the range covered by the StandardDate
' member of the TIME_ZONE_INFORMATION structure.
PRIVATE FUNCTION AfxTimeZoneIsStandardSavingTime () AS BOOLEAN
   DIM r AS DWORD = GetTimeZoneInformation(@tzi)
   RETURN (r = TIME_ZONE_ID_STANDARD)
PRIVATE FUNCTION AfxTimeZoneStandardDay () AS WORD
   IF r = TIME_ZONE_ID_INVALID THEN RETURN 0
   RETURN tzi.StandardDate.wDay
PRIVATE FUNCTION AfxTimeZoneStandardDayOfWeek () AS WORD
   RETURN tzi.StandardDate.wDayOfWeek
PRIVATE FUNCTION AfxTimeZoneStandardHour () AS WORD
   RETURN tzi.StandardDate.wHour
PRIVATE FUNCTION AfxTimeZoneStandardMonth () AS WORD
   RETURN tzi.StandardDate.wMonth
Richard Kelly
#5
Sorry to be a pest, and could you also include these functions?
PRIVATE FUNCTION AfxTimeZoneStandardMinute () AS WORD
   RETURN tzi.StandardDate.wMinute
PRIVATE FUNCTION AfxTimeZoneDaylightMinute () AS WORD
   RETURN tzi.DaylightDate.wMinute
Indeed. I already have updated the Git repository.
Richard Kelly
Thank you once again... :)
Paul: Will these changes make into the next WINFBE release?
Yes, the changes will. I normally take the latest copy of Jose's WinFBX github and copy the files into the WinFBE Suite distribution.
