Applause
Started by Petrus Vorster, July 16, 2020, 03:09:12 AM
One do not always appreciate the work you fellows do here.
Just for fun, I looked at another 64bit basic project and their "visual designer".
What a bunch of garbage. Slow, minimal options and a bunch of people still stuck on playing monopoly in 256 Colours.
For what reason would people still long for a 64bit Tool with a DOS interface?
You need to be commended. The tools in FF3 and what you are busy with in the new Freebasic Designer is truly in a different class.
Thanks for the smart and hard work you put into this.
-Peter
-Regards
Peter
Bumblebee
I second this :) :)
May this IDE receive all the publicity it deserves.
Failed pollinator.
philbar
Add my vote to that.
Most of the time, we only write in when we find a glitch or want something, so the occasional praise is definitely in order.
WinFBE is clean, responsive, and uncluttered. The Designer is intuitive, and it does what I want a designer to do. If there are any Windows features that are not addressed --yet-- José's remarkable WinFBX is lurking in the background to fill in the gaps. All that makes this a system for writing real programs.
Thanks guys - really appreciate the support!
We offer all the support you'll ever need...
