Author Topic: wishlist item ... if anyone could help me plz?  (Read 390 times)
veltesian
  • Little Newbie
« on: July 29, 2020, 11:09:21 AM »
one thing i would really love to create with winfbe... but i'm only sad that it probably cannot
be done. i want to be able to create a tone generator. even if its something simple, i'd be
happy for the while.
a tone generator with just the basic wave forms .... sawtooth, sine, square, triangle & noise.
jermy
Re: wishlist item ... if anyone could help me plz?
« Reply #1 on: July 29, 2020, 01:56:12 PM »
Hi veltesian
the most simple tone generator ever
Declare Function WinBeep Lib "kernel32" Alias "Beep" (ByVal dwFreq As Long, ByVal dwDuration As Long) As Long
 WinBeep 200, 2000
    Function = 0
Or you can use Josť Roca more complex piano demo at starting point.
https://github.com/JoseRoca/WinFBX  must to have
veltesian
  • Little Newbie
« Reply #2 on: July 29, 2020, 02:13:32 PM »
hello jermy....
that code does not show any errors.... but it does not work. sorry to tell you that jermy.
i thank you for your help though.
jermy
« Reply #3 on: July 29, 2020, 03:43:01 PM »
of course it is ... you forgot the click event in the toolbox?
veltesian
  • Little Newbie
« Reply #4 on: July 29, 2020, 09:57:50 PM »
hello jermy....
i unzipped the winbeep.zip into my folder where i would open the file(s)
i launched my winfbe,... and saw there were 2 workspace files
1. winbeep.bas
2. WinFBE_VD_MAIN.bas
i first opened winbeep.bas  <---- this file seemed to compile with no errors,... but there was no GUI or console
to even see on the screen. next i opened the WinFBE_VD_MAIN.bas <----- this file crashed after 2 or so seconds
of it attemping to be compiled....so i'm not really sure where to go from here. (gives a look of uncertainty)
« Last Edit: July 29, 2020, 10:00:53 PM by veltesian »
« Reply #5 on: July 29, 2020, 10:58:50 PM »
Jermy has provided a full archive as per my attached screenshot. The archive contains a WinFBE "project". You need to unzip the archive and use WinFBE's "Open Project" and select the file "WinBeep.wfbe"   <--- that is a WinFBE project file.
If you are creating any type of WinFBE visual designer project then I urge you to use the project features rather than building your gui just using one simple .bas form. It will be MUCH easier in the long run for you.
« Reply #6 on: July 29, 2020, 11:00:51 PM »
The WinFBE_VD_MAIN.bas is an autogenerated file created by WinFBE each time you compile your project. It is the main file that is fed to the FreeBasic compiler. You should not include that file in the project nor edit it as it gets recreated often.
veltesian
  • Little Newbie
« Reply #7 on: July 30, 2020, 11:24:42 PM »
thank you paul....
i appreciate your explaining about that. i'll definitely be mindful of any
warnings/advice for not editing too much unless i know what i am looking at.
