Author Topic: question about playing a sound?  (Read 300 times)
veltesian
  • Little Newbie
« on: July 30, 2020, 11:15:41 PM »
hello everyone...
i would like to know how can this 1 included *.bas could be fixed if possible? i had
ideas on building a simple SND player device if its ever possible. i might need to look
further perhaps as the code within the form of the included *.bas may not be right.
when i try to compile it for runtime,... the compiler seems to not like the declare function
& the "playsound" seems like an undefined variable. i'm not sure where to go from here.
(.... sigh) i guess i have a lot to learn about windows API or how to arrange such things.
« Last Edit: July 30, 2020, 11:21:16 PM by veltesian »
jermy
Re: question about playing a sound?
« Reply #1 on: July 31, 2020, 07:32:53 AM »
I think you used visual basic 6 in the past?
if so then you have some specific explanation in the project about the differences
veltesian
  • Little Newbie
« Reply #2 on: July 31, 2020, 07:50:04 AM »
hello jermy...
i just downloaded your playsound.zip and tried it. thanks it works great & yes i had
worked in vb6 (before .NET framework)... though i guess my zip upload was probably no good
to begin with. thats ok.... so i am sorry if it greatly disappoints anyone who might download it.
jermy
« Reply #3 on: August 01, 2020, 12:41:30 PM »
before I started freebasic I programmed a lot in vb6.
I have often used old vb6 code as it often works with minor changes.
On the way you learn the differences faster
