Author Topic: Problem with AfxOpenFileDialog from a child dialog  (Read 794 times)
James Klutho
« on: August 24, 2020, 12:45:45 AM »
I have been using WinFBE for a couple of months without problems until now.  I have a main parent window and call quite a few child windows and all is fine.  On one of the child windows I call AfxOpenFileDialog via a BUTTON control and it won't dismiss itself properly.  It keeps popping up.   AfxOpenFileDialog works fine in the parent window.  I think GetOpenFilenameW is getting confused with the multiple event loops. I messed with this quite a bit. I even tried to change the parent of AfxOpenFileDialog to the the DeskTopWindow but still no joy.  The problem, I think, lies in  pWindow->DoEvents(SW_SHOW).  Any thoughts?
« Last Edit: August 24, 2020, 09:55:47 AM by James Klutho »
Re: Problem with AfxOpenFileDialog from a child dialog
« Reply #1 on: August 24, 2020, 06:52:29 PM »
Hi Jim,
Just so that I understand 100%.... You have a main form and you are popping up additional dialogs (modal or modeless?), and on those popup dialogs you are pressing a button that shows the AfxOpenFileDialog dialog and it is that AfxOpenFileDialog that will not close?
I assume you are using Jose's Afx CWindow library directly and NOT the WinFBE visual designer, right?
James Klutho
« Reply #2 on: August 24, 2020, 07:12:51 PM »
That is correct.  It is all Jose's library.  The dialogs windows are all modal based on your About form of the code editor source code as a template.  When I call the AfxOpenFileDialog from a child dialog window, it just keeps popping up and I have to force a close by right clicking the icon in the bottom task bar.  When I change the parent of the AfxOpenFileDialog to the main form or the DeskTopWindow, I can eventually dismiss the AfxOpenFileDialog after having re-popped up  4 or 5 times.  I have to believe there is a conflict in the Event loops but I can't find it.  See if the same thing happens for you.
« Reply #3 on: August 24, 2020, 08:25:13 PM »
You must be doing something really weird. I have taken one of the templates that displays a popup dialog when  you click the "Popup" button and added a button labeled "Open File" to the popup dialog and it works fine.
' Microsoft Windows
' File: CW_PopupWindow.fbtpl
' Contents: CWindow with a modal popup window
' Copyright (c) 2016 Josť Roca. Freeware. Use at your own risk.
#define UNICODE
USING Afx
CONST IDC_POPUP = 1001
CONST IDC_OFD = 1002
' // Forward declarations
DECLARE FUNCTION WndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
DECLARE FUNCTION PopupWindow (BYVAL hParent AS HWND) AS LONG
DECLARE FUNCTION PopupWndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "CWindow with a popup window", @WndProc)
   pWindow.Center
   ' // Add a button without position or size (it will be resized in the WM_SIZE message).
   pWindow.AddControl("Button", , IDC_POPUP, "&Popup", 350, 250, 75, 23)
' Window procedure
FUNCTION WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_POPUP
                  PopupWindow(hwnd)
      CASE WM_SIZE
            ' // Resize the buttons
            pWindow->MoveWindow GetDlgItem(hwnd, IDC_POPUP), pWindow->ClientWidth - 120, pWindow->ClientHeight - 50, 75, 23, CTRUE
    CASE WM_DESTROY
         ' // Quit the application
         PostQuitMessage(0)
' Popup window procedure
   pWindow.Create(hParent, "Popup window", @PopupWndProc, , , , , _
      WS_VISIBLE OR WS_CAPTION OR WS_POPUPWINDOW OR WS_THICKFRAME, WS_EX_WINDOWEDGE)
   pWindow.Brush = GetStockObject(WHITE_BRUSH)
   pWindow.SetClientSize(300, 200)
   pWindow.Center(pWindow.hWindow, hParent)
   ' // Add a button
   pWindow.AddControl("Button", , IDC_OFD, "Open File", 150, 150, 75, 23)
   ' / Process Windows messages
   STATIC hNewFont AS HFONT
   SELECT CASE uMsg
      CASE WM_CREATE
         ' // Get a pointer to the CWindow class from the CREATESTRUCT structure
         DIM pWindow AS CWindow PTR = AfxcWindowPtr(lParam)
         ' // Create a new font scaled according the DPI ratio
         IF pWindow->DPI <> 96 THEN hNewFont = pWindow->CreateFont("Tahoma", 9)
         ' Disable parent window to make popup window modal
         EnableWindow GetParent(hwnd), FALSE
      CASE WM_COMMAND
            CASE IDCANCEL
            ' // Display the Open File Dialog
            CASE IDC_OFD
                  DIM wszFile AS WSTRING * 260 = "*.*"
                  DIM wszInitialDir AS STRING * 260 = CURDIR
                  DIM wszFilter AS WSTRING * 260 = "BAS files (*.BAS)|*.BAS|" & "All Files (*.*)|*.*|"
                  DIM dwFlags AS DWORD = OFN_EXPLORER OR OFN_FILEMUSTEXIST OR OFN_HIDEREADONLY
                  DIM cws AS CWSTR = AfxOpenFileDialog(hwnd, "", wszFile, wszInitialDir, wszFilter, "BAS", @dwFlags, NULL)
                  MessageBoxW(hwnd, cws, "File", MB_OK)
      CASE WM_PAINT
    DIM ps AS PAINTSTRUCT, hOldFont AS HFONT
         DIM hDC AS HDC = BeginPaint(hWnd, @ps)
         IF hNewFont THEN hOldFont = CAST(HFONT, SelectObject(hDC, CAST(HGDIOBJ, hNewFont)))
         DIM rc AS RECT
         GetClientRect(hWnd, @rc)
         DrawTextW(hDC, "Hello, World!", -1, @rc, DT_SINGLELINE or DT_CENTER or DT_VCENTER)
         IF hNewFont THEN SelectObject(hDC, CAST(HGDIOBJ, CAST(HFONT, hOldFont)))
         EndPaint(hWnd, @ps)
      CASE WM_CLOSE
         ' // Enables parent window keeping parent's zorder
         EnableWindow GetParent(hwnd), CTRUE
         ' // Don't exit; let DefWindowProcW perform the default action
    CASE WM_DESTROY
         ' // Destroy the new font
         IF hNewFont THEN DeleteObject(CAST(HGDIOBJ, hNewFont))
         PostQuitMessage(0)
James Klutho
« Reply #4 on: August 24, 2020, 10:14:30 PM »
Thanks Jose.  I got sloppy.  I stared at this for hours.  I forgot to wrap the code in a BN_CLICKED test.  Sorry for the bother.  I'm sailing again.
« Last Edit: August 24, 2020, 10:22:42 PM by James Klutho »
