Author Topic: Graphical Debugger for FreeBasic ??  (Read 884 times)
Softfoot
  • Little Newbie
« on: September 08, 2020, 10:57:31 AM »
Hi, I am running WinFBE and would like to find a graphical (GUI) debugger that works with it.
Are any known (that work) ??  I have tried FBDebugger v2.96 but it throws up a string of error messages when I start it.
Regards,
Dave
Re: Graphical Debugger for FreeBasic ??
« Reply #1 on: September 08, 2020, 01:20:21 PM »
Hi Dave there are none that I know of that work seamlessly with WinFBE (especially if you are using WinFBE's visual designer). sorry.
Softfoot
  • Little Newbie
« Reply #2 on: September 08, 2020, 01:28:50 PM »
OK Thanks
BTW Is there a tutorial for the "visual designer" particularly adding in the code that goes behind things like buttons and listboxes etc ???
Dave
