Author Topic: WinFBE 2.1.8 development  (Read 622 times)
« on: November 18, 2020, 08:52:01 AM »
Good morning folks,
I am finally back to coding the next version of WinFBE and hope to have it released very soon. I am just working through a number of issues and bugs that have been reported in the forum over the past few months.
Here is what has been fixed/added:
Version 2.1.8
Editor:
- Polish language file provided by Waldemar Pajak.
- Updated Italian language file provided by Massimiliano.
- For/Next loop variables were sometimes not being correctly identified when that option was enabled in Editor Options.
Visual Designer:
- DateTimePicker control: font property not set correctly at run time.
- Menu Editor: added blank line to dropdown Shortcut key combobox so you can unselect any previously set shortcut key.
- PictureBox control: added property 'ImageFromFile' to be able to load images from disk.
- ListBox: backcolor of an empty list box was not being handled correctly.
Here is what I am working on fixing:
- ListBox refresh issues
https://www.planetsquires.com/protect/forum/index.php?topic=4441.msg34542;topicseen#msg34542
- Multiline comment blocks in form functions with no other code causes function to be regenerated.
https://www.planetsquires.com/protect/forum/index.php?topic=4444.msg34632;topicseen#msg34632
- Default save file extension for new forms should be .inc (contained in Projects) in order to place them in the correct branch of the explorer tree.
https://www.freebasic.net/forum/viewtopic.php?f=8&t=25215&start=705#p277002
I do have other long standing issues that I will try to fix for the next release if I have time but the ones above are the primary ones that I want to get fixed.
philbar
  • Little Newbie
Re: WinFBE 2.1.8 development
« Reply #1 on: November 18, 2020, 11:04:44 AM »
Hi Paul, and Yay!
Specifically, the ImageFromFile property will be a welcome addition and should simplify things for me. Thanks.
Phil
« Reply #2 on: November 18, 2020, 01:36:24 PM »
Thanks for the update, Paul! :0)
