Version 2.1.8 (November 19, 2020)
Editor:
- Polish language file provided by Waldemar Pajak.
- Updated Italian language file provided by Massimiliano.
- For/Next loop variables were sometimes not being correctly identified when that option was enabled in Editor Options.
- Multiline comment blocks inside of sub/function blocks was not being parsed correctly causing sub/function definitions in the visual designer to be regenerated.
- The "Refresh" method would appear twice in the codetip popup menu for Forms.
- New Form files will default to .inc file extension if a project is active, otherwise the file extension will default to .bas.
Visual Designer:
- DateTimePicker control: font property not set correctly at run time.
- Menu Editor: added blank line to dropdown Shortcut key combobox so you can unselect any previously set shortcut key.
- PictureBox control: added property 'ImageFromFile' to be able to load images from disk.
- ListBox: backcolor of an empty list box was not being handled correctly.
Download from:
