Author Topic: Text File IO  (Read 470 times)
James Fuller
Text File IO
« on: December 20, 2020, 04:37:32 PM »
The WinFBX framework is all unicode.
Are there any examples using File IO ?
I find the FreeBasic Help File Open statement a bit confusing with no unicode example.
Thanks
James
Re: Text File IO
« Reply #1 on: December 20, 2020, 08:10:47 PM »
Re: Text File IO
« Reply #2 on: December 20, 2020, 08:26:43 PM »
Hi James, this type of code serves my purposes:
' Put and Get return 0 on success.
Dim As Long ff = FreeFile
Dim as Long o = Open( "C:\MyFile.dat" For Binary Access Read as #ff )
If o = 0 Then '' Good Open
'' variable to hold file data
Dim buffer as String
If LOF(ff) > 0 Then
'' our string has as many characters as the file has in bytes
buffer = String(LOF(ff), 0)
'' size of buffer is known. Entire string filled with file data
Get #ff, , buffer
'' Or
'' Put #ff, 1, buffer
'' I typically don't check the return value of Put or Get
Dim As Long c = Close(#ff) '' or Close(ff)
If c <> 0 Then
? "C:\MyFile.dat. Close Error: "; c
Else '' Bad Open
? "C:\MyFile.dat. open error: "; o
However, Jose's class will do a much better job!
Re: Text File IO
« Reply #3 on: December 20, 2020, 10:27:25 PM »
CTextStream works with ansi or unicode sequential files.
https://github.com/JoseRoca/WinFBX/blob/master/docs/File%20Management/CTextStream%20Class.md
CFileStream works with binary files.
https://github.com/JoseRoca/WinFBX/blob/master/docs/File%20Management/CFileStream%20Class.md
And, contrarily to FreeBasic Open function, they also accept unicode for the file names.
James Fuller
Re: Text File IO
« Reply #4 on: December 21, 2020, 06:20:31 AM »
José,
  This is the example from your help with an added else and it fails for me.
James
#define UNICODE
#INCLUDE ONCE "windows.bi"
#include "Afx/CTextStream.inc"
using Afx
' // Create an instance of the CTextStream class
DIM pTxtStm AS CTextStream
' // Open file for output as a text stream
IF pTxtStm.OpenForOutputW(ExePath & "\TestW.txt") = S_OK THEN
   ' // Write a string and an end of line to the stream
   pTxtStm.WriteLine "This is a test."
   '// Close the file
   pTxtStm.Close
Else
    ? "No GO"
PRINT "Press any key to end..."
SLEEP
Re: Text File IO
« Reply #5 on: December 21, 2020, 08:07:18 AM »
For all my programs, I changed the file handling to use Jose's CFileStream and CTextStream. Works perfectly with ansi and unicode and the syntax is simple as well.
James Fuller
Re: Text File IO
« Reply #6 on: December 21, 2020, 09:03:11 AM »
  Would you provide a small example of writing and reading a unicode text file?
Thank you,
James
Re: Text File IO
« Reply #7 on: December 21, 2020, 01:11:12 PM »
José,
James
The method has an optional parameter to create the file if it does not exist. Therefore, use:
IF pTxtStm.OpenForOutputW(ExePath & "\TestW.txt", TRUE) = S_OK THEN
« Last Edit: December 21, 2020, 01:13:47 PM by José Roca »
Re: Text File IO
« Reply #8 on: December 21, 2020, 01:23:28 PM »
In the documentation there are examples to write to a file under the Create, Open (and its variations),  Write, WriteLine,WriteBlankLines topics, and for reading under the ReadLine and ReadAll topics.
