Author Topic: Image manager  (Read 535 times)
jermy
Image manager
« on: January 24, 2021, 04:40:18 PM »
I noticed that the image manager crashes WinFbe when you select File...
maybe my WinFBE installation is damaged ?.
« Last Edit: January 24, 2021, 04:43:46 PM by jermy »
Re: Image manager
« Reply #1 on: January 25, 2021, 09:27:07 AM »
Thanks jermy, I believe your report is similar to the one VANYA also reported. I have recorded it on my to do list and will fix it all up for the next release.
