Author Topic: Very small Rebar  (Read 537 times)
jermy
Very small Rebar
« on: March 02, 2021, 02:23:56 PM »
I was looking for an example of a rebar, in the templats are a few examples.
The icons are very small on my screen, can I adjust that somewhere?
' Microsoft Windows
' File: CW_COMMCTRL_Rebar.fbtpl
' Contents: CWindow with a rebar control
' Copyright (c) 2016 Josť Roca. Freeware. Use at your own risk.
#define UNICODE
#define _WIN32_WINNT &h0602
USING Afx
CONST IDC_TOOLBAR = 1001
CONST IDC_CBBOX = 1002
CONST IDC_REBAR = 1003
enum
   IDM_CUT = 28000
   IDM_COPY, IDM_PASTE, IDM_UNDO, IDM_REDOW, IDM_DELETE, IDM_FILENEW, IDM_FILEOPEN
   IDM_FILESAVE, IDM_PRINTPRE, IDM_PROPERTIES, IDM_HELP, IDM_FIND, IDM_REPLACE, IDM_PRINT
end enum
' // Forward declaration
' Create the toolbar
FUNCTION CreateToolbar (BYVAL pWindow AS CWindow PTR) AS HWND
   ' // Add a tooolbar
   DIM hToolBar AS HWND = pWindow->AddControl("Toolbar", , IDC_TOOLBAR, "", , , , , _
      WS_CHILD OR WS_VISIBLE OR TBSTYLE_TOOLTIPS OR TBSTYLE_FLAT OR CCS_NODIVIDER OR CCS_NORESIZE OR CCS_NOPARENTALIGN)
   ' // Allow drop down arrows
   Toolbar_SetExtendedStyle(hToolBar, TBSTYLE_EX_DRAWDDARROWS)
   ' // Add a bitmap with the button images
   DIM ttbab AS TBADDBITMAP
   ttbab.hInst = HINST_COMMCTRL
   IF AfxIsProcessDPIAware THEN
      ttbab.nId = IDB_STD_LARGE_COLOR
      ttbab.nId = IDB_STD_SMALL_COLOR
   Toolbar_AddBitmap(hToolBar, 0, @ttbab)
   ' // Add buttons to the toolbar
   Toolbar_AddButton hToolBar, STD_CUT, IDM_CUT
   Toolbar_AddButton hToolBar, STD_COPY, IDM_COPY
   Toolbar_AddButton hToolBar, STD_PASTE, IDM_PASTE
   Toolbar_AddButton hToolBar, STD_DELETE, IDM_DELETE
   Toolbar_AddSeparator hToolBar
   Toolbar_AddButton hToolBar, STD_UNDO, IDM_UNDO
   Toolbar_AddButton hToolBar, STD_REDOW, IDM_REDOW
   Toolbar_AddButton hToolBar, STD_FILENEW, IDM_FILENEW, 0, BTNS_DROPDOWN
   Toolbar_AddButton hToolBar, STD_FILEOPEN, IDM_FILEOPEN
   Toolbar_AddButton hToolBar, STD_FILESAVE, IDM_FILESAVE
   Toolbar_AddButton hToolBar, STD_PRINTPRE, IDM_PRINTPRE
   Toolbar_AddButton hToolBar, STD_FIND, IDM_FIND
   Toolbar_AddButton hToolBar, STD_REPLACE, IDM_REPLACE
   Toolbar_AddButton hToolBar, STD_PROPERTIES, IDM_PROPERTIES
   Toolbar_AddButton hToolBar, STD_PRINT, IDM_PRINT
   Toolbar_AddButton hToolBar, STD_HELP, IDM_HELP
   ' // Size the toolbar
   Toolbar_AutoSize(hToolBar)
   ' // Return the toolbar handle
   FUNCTION = hToolbar
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "CWindow with a rebar", @WndProc)
   ' // Disable background erasing
   pWindow.ClassStyle = CS_DBLCLKS
   ' // Set the client size
   pWindow.SetClientSize(600, 250)
   ' // Center the window
   pWindow.Center
   ' // Add a button
   DIM hButton AS HWND = pWindow.AddControl("Button", , IDCANCEL, "&Close")
   ' // Create a rebar control
   DIM hRebar AS HWND = pWindow.AddControl("Rebar", , IDC_REBAR)
   ' // Create the toolbar
   DIM hToolbar AS HWND = CreateToolbar(@pWindow)
   ' // Add the band containing the toolbar control to the rebar
   ' // The size of the REBARBANDINFOW is different in Vista/Windows 7
   DIM rc AS RECT, wszText AS WSTRING * 260
   DIM rbbi AS REBARBANDINFOW
   IF AfxWindowsVersion >= 600 AND AfxComCtlVersion >= 600 THEN
      rbbi.cbSize  = REBARBANDINFO_V6_SIZE
      rbbi.cbSize  = REBARBANDINFO_V3_SIZE
   ' // Insert the toolbar in the rebar control
   rbbi.fMask      = RBBIM_STYLE OR RBBIM_CHILD OR RBBIM_CHILDSIZE OR _
                     RBBIM_SIZE OR RBBIM_ID OR RBBIM_IDEALSIZE OR RBBIM_TEXT
   rbbi.fStyle     = RBBS_CHILDEDGE
   rbbi.hwndChild  = hToolbar
   rbbi.cxMinChild = 270 * pWindow.rxRatio
   rbbi.cyMinChild = Toolbar_GetButtonHeight(hToolbar)
   rbbi.cx         = 270 * pWindow.rxRatio
   rbbi.cxIdeal    = 270 * pWindow.rxRatio
   wszText = "Toolbar"
   rbbi.lpText = @wszText
   '// Insert band into rebar
   Rebar_InsertBand(hRebar, -1, @rbbi)
    SendMessageW ( hRebar, TB_SETBUTTONSIZE, 0, MAKELONG(64, 64))
'   ' // Insert a combobox in the rebar control
   DIM hCbBox AS HWND = pWindow.AddControl("ComboBox", , IDC_CBBOX, "", 0, 0, 0, 50 * pWindow.rxRatio)
   GetWindowRect hCbBox, @rc
   rbbi.fStyle     = RBBS_FIXEDSIZE OR RBBS_CHILDEDGE
   rbbi.hwndChild  = hCbBox
   rbbi.cxMinChild = 200 * pWindow.rxRatio
   rbbi.cyMinChild = rc.Bottom - rc.Top
   rbbi.cx         = 200 * pWindow.rxRatio
   rbbi.cxIdeal    = 200 * pWindow.rxRatio
   wszText = "Combobox"
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
'            CASE IDM_CUT   ' etc.
'               MessageBoxW hwnd, "You have clicked the Cut button", "Toolbar", MB_OK
'               EXIT FUNCTION
      CASE WM_NOTIFY
         ' Notification messages are handled here.
         ' The TTN_GETDISPINFO message is sent by a ToolTip control
         ' to retrieve information needed to display a ToolTip window.
         DIM ptnmhdr AS NMHDR PTR              ' // Information about a notification message
         DIM ptttdi AS NMTTDISPINFOW PTR       ' // Tooltip notification message information
         DIM wszTooltipText AS WSTRING * 260   ' // Tooltip text
         ptnmhdr = CAST(NMHDR PTR, lParam)
         SELECT CASE ptnmhdr->code
            ' // The height of the rebar has changed
            CASE RBN_HEIGHTCHANGE
               ' // Get the coordinates of the client area
               DIM rc AS RECT
               GetClientRect hwnd, @rc
               ' // Send a WM_SIZE message to resize the controls
               SendMessageW hwnd, WM_SIZE, SIZE_RESTORED, MAKELONG(rc.Right - rc.Left, rc.Bottom - rc.Top)
            ' // Toolbar tooltips
            CASE TTN_GETDISPINFOW
               ptttdi = CAST(NMTTDISPINFOW PTR, lParam)
               ptttdi->hinst = NULL
               wszTooltipText = ""
               SELECT CASE ptttdi->hdr.hwndFrom
                  CASE Toolbar_GetTooltips(GetDlgItem(GetDlgItem(hwnd, IDC_REBAR), IDC_TOOLBAR))
                     SELECT CASE ptttdi->hdr.idFrom
                        CASE IDM_CUT        : wszTooltipText = "Cut"
                        CASE IDM_COPY       : wszTooltipText = "Copy"
                        CASE IDM_PASTE      : wszTooltipText = "Paste"
                        CASE IDM_UNDO       : wszTooltipText = "Undo"
                        CASE IDM_REDOW      : wszTooltipText = "Redo"
                        CASE IDM_DELETE     : wszTooltipText = "Delete"
                        CASE IDM_FILENEW    : wszTooltipText = "File New"
                        CASE IDM_FILEOPEN   : wszTooltipText = "File Open"
                        CASE IDM_FILESAVE   : wszTooltipText = "File Save"
                        CASE IDM_PRINTPRE   : wszTooltipText = "Print Preview"
                        CASE IDM_PROPERTIES : wszTooltipText = "Properties"
                        CASE IDM_HELP       : wszTooltipText = "Help"
                        CASE IDM_FIND       : wszTooltipText = "Find"
                        CASE IDM_REPLACE    : wszTooltipText = "Replace"
                        CASE IDM_PRINT      : wszTooltipText = "Print"
                     IF LEN(wszTooltipText) THEN ptttdi->lpszText = @wszTooltipText
         CASE TBN_DROPDOWN
            DIM ptbn AS TBNOTIFY PTR = CAST(TBNOTIFY PTR, lParam)
            SELECT CASE ptbn->iItem
               CASE IDM_FILENEW
                  DIM rc AS RECT
                  Toolbar_GetRect(ptbn->hdr.hwndFrom, ptbn->iItem, @rc)
                  MapWindowPoints(ptbn->hdr.hwndFrom, HWND_DESKTOP, CAsT(LPPOINT, @rc), 2)
                  DIM hPopupMenu AS HMENU = CreatePopUpMenu
                  AppendMenuW hPopupMenu, MF_ENABLED, 10001, "Option 1"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10002, "Option 2"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10003, "Option 3"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10004, "Option 4"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10005, "Option 5"
                  TrackPopupMenu(hPopupMenu, 0, rc.Left, rc.Bottom, 0, hwnd, NULL)
                  DestroyMenu hPopupMenu
      CASE WM_SIZE
            ' // Update the size and position of the Rebar control
            SendMessageW GetDlgItem(hwnd, IDC_REBAR), WM_SIZE, wParam, lParam
            ' // Resize the button
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 95, pWindow->ClientHeight - 35, 75, 23, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
Thanks in advance for your help
jermy
Re: Very small Rebar
« Reply #1 on: March 15, 2021, 03:40:56 PM »
my description was not clear, given the number of responses.
Fortunately, I was able to solve it myself
