After a long search, this is the solution
#define UNICODE
#include once "Afx/CWindow.inc"
USING Afx
CONST IDC_POPUP = 1001
Dim Shared as Hwnd HWND_WORKSPACEMAIN
' // Forward declarations
DECLARE FUNCTION WndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
DECLARE FUNCTION PopupWindow (BYVAL hParent AS HWND) AS CWindow PTR
DECLARE FUNCTION PopupWndProc (BYVAL hWnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
' Main
' // Set process DPI aware
AfxSetProcessDPIAware
' // Create the main window
DIM pWindow AS CWindow
DIM hWndMain AS HWND = pWindow.Create(NULL, "Modeless popup window", @WndProc)
pWindow.SetClientSize(900, 500)
pWindow.Center
' // Add a button without position or size (it will be resized in the WM_SIZE message).
pWindow.AddControl("Button", , IDC_POPUP, "&Popup")
' // Display the window
ShowWindow(hWndMain, nCmdShow)
UpdateWindow(hWndMain)
DIM uMsg AS MSG, hFocusWnd AS HWND
WHILE (GetMessageW(@uMsg, NULL, 0, 0) <> FALSE)
' // Check if a popup dialog is activated and get its handle
if HWND_WORKSPACEMAIN = GetFocus() then
hFocusWnd = HWND_WORKSPACEMAIN
else
hFocusWnd = hWndMain
' // Process Windows messages
IF IsDialogMessageW(hFocusWnd, @uMsg) = 0 THEN
TranslateMessage(@uMsg)
DispatchMessageW(@uMsg)
WEND
FUNCTION = uMsg.wParam
' Window procedure
FUNCTION WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
SELECT CASE uMsg
CASE WM_COMMAND
CASE IDCANCEL
CASE IDC_POPUP
PopupWindow(hwnd)
CASE WM_SIZE
' // Resize the button
pWindow->MoveWindow GetDlgItem(hwnd, IDC_POPUP), pWindow->ClientWidth - 140, pWindow->ClientHeight - 40, 75, 23, CTRUE
CASE WM_DESTROY
' // Quit the application
PostQuitMessage(0)
' Popup main window
DIM pWindow AS CWindow PTR = NEW CWindow
pWindow->Create(hParent, "Popup window", @PopupWndProc, 0, 0, 0, 0, _
WS_POPUPWINDOW OR WS_CAPTION OR WS_CLIPSIBLINGS OR WS_CLIPCHILDREN OR WS_THICKFRAME, _
WS_EX_CONTROLPARENT OR WS_EX_WINDOWEDGE)
pWindow->Brush = GetStockObject(WHITE_BRUSH)
pWindow->SetClientSize(700, 400)
pWindow->Center(pWindow->hWindow, hParent)
ShowWindow(pWindow->hWindow, SW_NORMAL)
UpdateWindow(pWindow->hWindow)
FUNCTION = pWindow
' Popup window procedure
SELECT CASE uMsg
CASE WM_COMMAND
CASE IDCANCEL
CASE WM_DESTROY
' // Delete the popup CWindow class
IF pWindow THEN Delete pWindow
