Author Topic: Intellisense-Listbox not drawn correctly  (Read 374 times)
jermy
« on: April 10, 2021, 02:39:46 PM »
Dear people,
The intention is that if you hit a dot on your keyboard that the list box will appear
Why is the listbox only half displayed ?.
#define UNICODE
#INCLUDE ONCE "Afx/AfxRichEdit.inc"
USING Afx
#define IDC_RICHEDIT 1001
#define IDC_LISTBOX   1002
' // Forward declaration
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create( NULL, "CWindow with a Rich Edit control", @WndProc )
   pWindow.SetClientSize(600, 420)
   pWindow.Center
   ' // Add a rich edit control without coordinates (it will be resized in WM_SIZE)
   DIM hRichEdit AS HWND = pWindow.AddControl( "RichEdit", , IDC_RICHEDIT, "RichEdit box" )
      ' // Enable EN_MSGFILTER notifications for keyboard events.
   RichEdit_SetEventMask( hRichEdit, ENM_KEYEVENTS or ENM_MOUSEEVENTS )
   SetFocus hRichEdit
Dim as long  dwStyle     =  WS_VSCROLL  'WS_CHILD OR WS_VISIBLE OR WS_HSCROLL OR WS_VSCROLL OR WS_BORDER OR WS_TABSTOP OR LBS_STANDARD OR LBS_HASSTRINGS OR LBS_SORT OR LBS_NOTIFY
Dim as long  dwExStyle = 0 'WS_EX_CLIENTEDGE 'or WS_EX_TOPMOST
   ' // Adds a listbox
   DIM hListBox AS HWND = pWindow.AddControl("ListBox", Null, IDC_LISTBOX, "", 400, 8, 100, 40, dwStyle, dwExStyle, 0, Null, &HFFFFFFFF, Null)
   ' // Fill the list box
   DIM wszText AS WSTRING * 260
   FOR i AS LONG = 1 TO 5
      wszText = "Item " & RIGHT("00" & WSTR(i), 2)
      ListBox_AddString(hListBox, @wszText)
   NEXT i
   ' // Select the first item
   ListBox_SetCursel(hListBox, 0)
   updateWindow hListBox
Static pWindow as Cwindow ptr
 dim as LPNMHDR pnm
  dim as MSGFILTER ptr pmf
   SELECT CASE uMsg
      CASE WM_CREATE
                 pWindow = AfxCWindowPtr(lParam)
      CASE WM_COMMAND
            CASE IDCANCEL
        Case WM_NOTIFY
               pnm = cast(LPNMHDR, lParam)
            if pnm->hwndFrom = GetDlgItem(hwnd, IDC_RICHEDIT) then
                select case pnm->code
                    case EN_MSGFILTER
                           pmf = cast(MSGFILTER ptr, pnm)
                        select case   pmf->msg
                              Case WM_KEYDOWN
                                  if pmf->wParam = 190 then         ' 190 = dot              ' GetPositionFromCharIndex
         ' get the cursor position in the rich edit box
         Dim as DWORD CursorPos
         SendMessage( pnm->hwndFrom, EM_GETSEL, NULL, cast(LPARAM, @CursorPos) )
         ' get the x and y coordinates from the cursor
         Dim pt As point
          SendMessage( pnm->hwndFrom, EM_POSFROMCHAR, cast(WPARAM,@pt), CursorPos )
         ' show the listbox
          pWindow->SetWindowPos GetDlgItem(hwnd, IDC_LISTBOX), Null, pWindow->UnScaleX(pt.x) + 15, pWindow->UnScaleY(pt.y) + 10, 100, 40, SWP_SHOWWINDOW
          updatewindow   pnm->hwndFrom
          SetFocus GetDlgItem(hwnd, IDC_LISTBOX)
                        end select
      CASE WM_SIZE
         ' // If the window isn't minimized, resize it
            ' // Resize the controls
            IF pWindow THEN
               pWindow->MoveWindow GetDlgItem(hwnd, IDC_RICHEDIT), 10, 10, pWindow->ClientWidth - 220, pWindow->ClientHeight - 220, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
I've already tried everything that came to my mind, anyone else have an idea?
Re: Intellisense-Listbox not drawn correctly
« Reply #1 on: April 10, 2021, 03:10:20 PM »
You only have made it 40 pixels tall. Make it bigger.
jermy
« Reply #2 on: April 10, 2021, 03:21:01 PM »
I tried that, then the first item is not visible.
« Reply #3 on: April 10, 2021, 03:31:10 PM »
It is being overwritten by the RichEdit control. Change the position of the ListBox.
jermy
« Reply #4 on: April 10, 2021, 03:46:51 PM »
yes that's it, thanks.
How can I be so blind? It must be because of corona.
          pWindow->SetWindowPos GetDlgItem(hwnd, IDC_LISTBOX), Null, pWindow->UnScaleX(pt.x) + 15, pWindow->UnScaleY(pt.y) + 27, 100, 80, SWP_SHOWWINDOW
« Last Edit: April 10, 2021, 04:30:16 PM by jermy »
