Hello people,
i am trying to draw with drawtext in a richedit control 'hello world' it works but the text is very small.
I don't know how to scale this correctly.
#define UNICODE
USING Afx
CONST IDC_RICHEDIT = 1001
' // Forward declaration
Declare FUNCTION RichEdit_SubclassProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM, BYVAL uIdSubclass AS UINT_PTR, BYVAL dwRefData AS DWORD_PTR) AS LRESULT
' Main
' // Set process DPI aware
AfxSetProcessDPIAware
DIM pWindow AS CWindow
pWindow.Create(NULL, "CWindow with a Rich Edit control", @WndProc)
pWindow.Center
DIM hRichEdit AS HWND = pWindow.AddControl("RichEdit", , IDC_RICHEDIT, "", 350, 250, 75, 23, , , , CAST(SUBCLASSPROC, @RichEdit_SubclassProc), IDC_RICHEDIT, CAST(DWORD_PTR, @pWindow))
SetFocus hRichEdit
' Processes messages for the subclassed RichEdit window.
FUNCTION RichEdit_SubclassProc ( BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM, BYVAL uIdSubclass AS UINT_PTR, BYVAL dwRefData AS DWORD_PTR ) AS LRESULT
SELECT CASE uMsg
Case WM_PAINT
DIM hDC AS HDC
Dim As RECT rect
DefSubclassProc(hwnd, uMsg, wParam, lParam)
hdc = GetDC(hWnd)
SetBkMode(hdc,TRANSPARENT)
SendMessageW( hWnd, EM_GETRECT, 0, cast(LPARAM, @rect) )
DrawTextW(hdc,"Hello World",-1,@rect,0)
DeleteDC(hdc)
CASE WM_DESTROY
' // REQUIRED: Remove control subclassing
RemoveWindowSubclass hwnd, @RichEdit_SubclassProc, uIdSubclass
FUNCTION = DefSubclassProc(hwnd, uMsg, wParam, lParam)
SELECT CASE uMsg
CASE WM_COMMAND
CASE IDCANCEL
CASE WM_SIZE
' // If the window isn't minimized, resize it
' // Resize the controls
IF pWindow THEN
pWindow->MoveWindow GetDlgItem(hwnd, IDC_RICHEDIT), 100, 50, pWindow->ClientWidth - 200, pWindow->ClientHeight - 150, CTRUE
CASE WM_DESTROY
PostQuitMessage(0)
it is possible to inherit the scaling, font, etc. from the RichEdit control so that the text being drawn looks the same as the typed version?
