Author Topic: Always on top  (Read 341 times)
Bumblebee
Always on top
« on: November 26, 2021, 04:24:30 PM »
How would I go about creating a window or form that remains always on top?
David Kenny
  • Windows 7 & 10
Re: Always on top
« Reply #1 on: November 26, 2021, 07:26:16 PM »
Take a look at SetWindowPos, the second parameter should be HWND_TOPMOST.
Re: Always on top
« Reply #2 on: November 26, 2021, 07:32:06 PM »
David beat me to it as I was testing code to post! First time I've coded in WinFBE in a while and I lost out on providing the answer. LOL
   SetWindowPos( sender.hWindow, HWND_TOPMOST, 0, 0, 0, 0, SWP_NOMOVE or SWP_NOSIZE )
   Function = 0
David Kenny
  • Windows 7 & 10
Re: Always on top
« Reply #3 on: November 26, 2021, 07:44:21 PM »
Well, since I didn't provide a tested example, your post is more useful.  :)
Bumblebee
Re: Always on top
« Reply #4 on: November 26, 2021, 11:12:39 PM »
Excellent, this does the trick. Thanks again!
Re: Always on top
« Reply #5 on: December 01, 2021, 11:41:19 AM »
Out of pure curiosity, the TOPMOST setting in a SetwindowsPOS, will it keep your form on top no matter what?
I was wondering what happens if you call other programs or forms with that setting, or will it keep the last called one on top?
Just curious if you have more than one of these what happens?
Regards, Peter
Bumblebee
Re: Always on top
« Reply #6 on: December 02, 2021, 11:45:36 AM »
Calling another program where it is set to always be on top, does place it on top.
