WinFBE 3.3.0 AutoComplete
Started by SeaVipe, April 01, 2022, 08:18:00 PM
The AutoComplete for forms controls on my PC at least usually works perfectly when first run for the day. At some point, it stops working and the only way to get it back is to close WinFBE and wait about 10 minutes before restarting WinFBE. I've never timed this exactly. I usually close most other apps but I'm not sure that's really necessary. Unscientific but it gets the job done - for a while.
Thanks Clive, I intend to revisit the whole autocomplete/intellisense style popups. It can be inconsistent. I need to rework the parsing code and make it more robust. That will probably not happen for the V3.0 release but it should come shortly thereafter.
