Author Topic: WinFBE 2.2.0 - how to update compiler folder  (Read 93 times)
Jim Dunn
  • Jim Dunn
« on: April 16, 2022, 09:21:45 PM »
I wanted to update the "FreeBASIC/gcc" folder in my WinFBE folder from 1.07 to 1.09...
But noticed the following differences (listed below).
Can you offer some guidance on which files/folders really need to be copied from the old 1.07.2-gcc-5.2 folder?
Thx!  : )
Jim
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\dislin.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\gettext-po.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\goocanvas.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\japi.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\jni.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\jpgalleg.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\libintl.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\pdflib.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\quicklz.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\tinyptc.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\Afx (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\big_int (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\crt\linux\stdlib.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\glade (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\libart_lgpl (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\mysql (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\spidermonkey (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\ddk\ddk_ntstatus.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\ddk\mmddk.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\ddk\winddk.bi
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\commctrl.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\dde.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\dlgs.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\prsht.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\windows.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\winerror.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\winnt.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\winuser.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\win\rc\winver.h
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\WinFormsX (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\inc\wx-c (entire folder)
D:\WinFBE_Suite\FreeBASIC-1.07.2-gcc-5.2\lib\win64 (463 .dll.a files)
Jim Dunn
  • Jim Dunn
Re: WinFBE 2.2.0 - how to update compiler folder
« Reply #1 on: April 16, 2022, 09:35:54 PM »
Oh, nevermind... I see there's a new BETA that uses a "ToolChains" folder... I'll just use the beta... thx!
