RTF
Started by SeaVipe, August 05, 2022, 06:43:47 PM
Hi all,
I'm trying to display just the text from RTF text by stripping out the RTF code. I've managed to remove about half the RTF but I get the feeling I'm trying to reinvent the wheel.
The RTF is displayed in a ListView so it has to be raw text.
If anyone has any suggestions please let me know...
Thanks.
I did a little google'ing and a simple approach that some people use is to have a hidden rich edit control and use that control to set and retrieve the text thereby avoiding having to deal with the embedded RTF codes. Basically, allow the RTF control to act as the converter for your strings.
Thanks, Paul,
Yes, I saw that too. My concern would be speed. The ListView displays about 20(ish) words from a BLOB field I call "comments" - which is in RTF format. The ListView Mouse_Move event builds a ToolTip based on the Row/Col cell content. The content was plain text but now that I'm delving into SQLite that content is RTF, which both the ListView and the tooltip display as text including the underlying RTF code.
Over the years I've used RTF to create various reports and other such documents, which has given me a fundamental grasp of RTF. In its current state, my RTF stripper algorithm is doing just the basics like removing "\pard", "\tab",  etc. as well as the actual RTF header up to the start of the body text. I've tried a variety of techniques and have settled on Mid() but so far all I've been able to do is return a text string from an RTF string that is full of blank spaces where the RTF code was. Once I figure out how to remove the blank spaces, it may actually Work.
I found 'Rich Text Stripper' online. Although I can read and to a limited degree understand it, the following is well above my pay grade!
    /// <summary>
    /// Rich Text Stripper
    /// </summary>
    /// <remarks>
    /// Translated from Python located at:
    /// http://stackoverflow.com/a/188877/448
    /// </remarks>
    public static class RichTextStripper
        private class StackEntry
            public int NumberOfCharactersToSkip { get; set; }
            public bool Ignorable { get; set; }
            public StackEntry(int numberOfCharactersToSkip, bool ignorable)
                NumberOfCharactersToSkip = numberOfCharactersToSkip;
                Ignorable = ignorable;
        private static readonly Regex _rtfRegex = new Regex(@"\\([a-z]{1,32})(-?\d{1,10})?[ ]?|\\'([0-9a-f]{2})|\\([^a-z])|([{}])|[\r\n]+|(.)", RegexOptions.Singleline | RegexOptions.IgnoreCase);
        private static readonly List<string> destinations = new List<string>
        "aftncn","aftnsep","aftnsepc","annotation","atnauthor","atndate","atnicn","atnid",
        "atnparent","atnref","atntime","atrfend","atrfstart","author","background",
        "bkmkend","bkmkstart","blipuid","buptim","category","colorschememapping",
        "colortbl","comment","company","creatim","datafield","datastore","defchp","defpap",
        "do","doccomm","docvar","dptxbxtext","ebcend","ebcstart","factoidname","falt",
        "fchars","ffdeftext","ffentrymcr","ffexitmcr","ffformat","ffhelptext","ffl",
        "ffname","ffstattext","field","file","filetbl","fldinst","fldrslt","fldtype",
        "fname","fontemb","fontfile","fonttbl","footer","footerf","footerl","footerr",
        "footnote","formfield","ftncn","ftnsep","ftnsepc","g","generator","gridtbl",
        "header","headerf","headerl","headerr","hl","hlfr","hlinkbase","hlloc","hlsrc",
        "hsv","htmltag","info","keycode","keywords","latentstyles","lchars","levelnumbers",
        "leveltext","lfolevel","linkval","list","listlevel","listname","listoverride",
        "listoverridetable","listpicture","liststylename","listtable","listtext",
        "lsdlockedexcept","macc","maccPr","mailmerge","maln","malnScr","manager","margPr",
        "mbar","mbarPr","mbaseJc","mbegChr","mborderBox","mborderBoxPr","mbox","mboxPr",
        "mchr","mcount","mctrlPr","md","mdeg","mdegHide","mden","mdiff","mdPr","me",
        "mendChr","meqArr","meqArrPr","mf","mfName","mfPr","mfunc","mfuncPr","mgroupChr",
        "mgroupChrPr","mgrow","mhideBot","mhideLeft","mhideRight","mhideTop","mhtmltag",
        "mlim","mlimloc","mlimlow","mlimlowPr","mlimupp","mlimuppPr","mm","mmaddfieldname",
        "mmath","mmathPict","mmathPr","mmaxdist","mmc","mmcJc","mmconnectstr",
        "mmconnectstrdata","mmcPr","mmcs","mmdatasource","mmheadersource","mmmailsubject",
        "mmodso","mmodsofilter","mmodsofldmpdata","mmodsomappedname","mmodsoname",
        "mmodsorecipdata","mmodsosort","mmodsosrc","mmodsotable","mmodsoudl",
        "mmodsoudldata","mmodsouniquetag","mmPr","mmquery","mmr","mnary","mnaryPr",
        "mnoBreak","mnum","mobjDist","moMath","moMathPara","moMathParaPr","mopEmu",
        "mphant","mphantPr","mplcHide","mpos","mr","mrad","mradPr","mrPr","msepChr",
        "mshow","mshp","msPre","msPrePr","msSub","msSubPr","msSubSup","msSubSupPr","msSup",
        "msSupPr","mstrikeBLTR","mstrikeH","mstrikeTLBR","mstrikeV","msub","msubHide",
        "msup","msupHide","mtransp","mtype","mvertJc","mvfmf","mvfml","mvtof","mvtol",
        "mzeroAsc","mzeroDesc","mzeroWid","nesttableprops","nextfile","nonesttables",
        "objalias","objclass","objdata","object","objname","objsect","objtime","oldcprops",
        "oldpprops","oldsprops","oldtprops","oleclsid","operator","panose","password",
        "passwordhash","pgp","pgptbl","picprop","pict","pn","pnseclvl","pntext","pntxta",
        "pntxtb","printim","private","propname","protend","protstart","protusertbl","pxe",
        "result","revtbl","revtim","rsidtbl","rxe","shp","shpgrp","shpinst",
        "shppict","shprslt","shptxt","sn","sp","staticval","stylesheet","subject","sv",
        "svb","tc","template","themedata","title","txe","ud","upr","userprops",
        "wgrffmtfilter","windowcaption","writereservation","writereservhash","xe","xform",
        "xmlattrname","xmlattrvalue","xmlclose","xmlname","xmlnstbl",
        "xmlopen"
        private static readonly Dictionary<string, string> specialCharacters = new Dictionary<string, string>
        { "par", "\n" },
        { "sect", "\n\n" },
        { "page", "\n\n" },
        { "line", "\n" },
        { "tab", "\t" },
        { "emdash", "\u2014" },
        { "endash", "\u2013" },
        { "emspace", "\u2003" },
        { "enspace", "\u2002" },
        { "qmspace", "\u2005" },
        { "bullet", "\u2022" },
        { "lquote", "\u2018" },
        { "rquote", "\u2019" },
        { "ldblquote", "\u201C" },
        { "rdblquote", "\u201D" },
        /// <summary>
        /// Strip RTF Tags from RTF Text
        /// </summary>
        /// <param name="inputRtf">RTF formatted text</param>
        /// <returns>Plain text from RTF</returns>
        public static string StripRichTextFormat(string inputRtf)
            if (inputRtf == null)
                return null;
            string returnString;
            var stack = new Stack<StackEntry>();
            bool ignorable = false;              // Whether this group (and all inside it) are "ignorable".
            int ucskip = 1;                      // Number of ASCII characters to skip after a unicode character.
            int curskip = 0;                     // Number of ASCII characters left to skip
            var outList = new List<string>();    // Output buffer.
            MatchCollection matches = _rtfRegex.Matches(inputRtf);
            if (matches.Count > 0)
                foreach (Match match in matches)
                    string word = match.Groups[1].Value;
                    string arg = match.Groups[2].Value;
                    string hex = match.Groups[3].Value;
                    string character = match.Groups[4].Value;
                    string brace = match.Groups[5].Value;
                    string tchar = match.Groups[6].Value;
                    if (!String.IsNullOrEmpty(brace))
                        curskip = 0;
                        if (brace == "{")
                            // Push state
                            stack.Push(new StackEntry(ucskip, ignorable));
                        else if (brace == "}")
                            // Pop state
                            StackEntry entry = stack.Pop();
                            ucskip = entry.NumberOfCharactersToSkip;
                            ignorable = entry.Ignorable;
                    else if (!String.IsNullOrEmpty(character)) // \x (not a letter)
                        curskip = 0;
                        if (character == "~")
                            if (!ignorable)
                                outList.Add("\xA0");
                        else if ("{}\\".Contains(character))
                            if (!ignorable)
                                outList.Add(character);
                        else if (character == "*")
                            ignorable = true;
                    else if (!String.IsNullOrEmpty(word)) // \foo
                        curskip = 0;
                        if (destinations.Contains(word))
                            ignorable = true;
                        else if (ignorable)
                        else if (specialCharacters.ContainsKey(word))
                            outList.Add(specialCharacters[word]);
                        else if (word == "uc")
                            ucskip = Int32.Parse(arg);
                        else if (word == "u")
                            int c = Int32.Parse(arg);
                            if (c < 0)
                                c += 0x10000;
                            outList.Add(Char.ConvertFromUtf32(c));
                            curskip = ucskip;
                    else if (!String.IsNullOrEmpty(hex)) // \'xx
                        if (curskip > 0)
                            curskip -= 1;
                        else if (!ignorable)
                            int c = Int32.Parse(hex, System.Globalization.NumberStyles.HexNumber);
                    else if (!String.IsNullOrEmpty(tchar))
                        if (curskip > 0)
                            curskip -= 1;
                            outList.Add(tchar);
            else
                // Didn't match the regex
                returnString = inputRtf;
            returnString = String.Join(String.Empty, outList.ToArray());
            return returnString;
Have you tried the RTF control approach? I imagine that you would create a hidden RTF control only once at form creation rather than every time a conversion is needed. Then you'd simply need to set and retrieve the text from the control and let the control handle the stripping. I expect that would be super fast even when compared to a dedicated function like you have posted which does seem to perform a lot of slow parsing and string operations. I would be surprised if there is any significant performance penalty that you would notice. I could be wrong, but that is my initial feeling.
Thanks, Paul,
I'm probably overthinking this, I'll try the RTF control approach.
