WinFBE v3.0.4 (December 13, 2022)
Started by Paul Squires, December 13, 2022, 07:27:58 PM
Download:  https://github.com/PaulSquires/WinFBE/releases
Version 3.0.4 (December 13, 2022)
Editor:
- Fixed ENUM code parsing and autocomplete popup.
- Fixed DIM AS autocomplete popup not reducing popup list as word is being typed.
- Fixed regression whereby Ctrl+S Save (or SaveAs) with no open documents would crash the application.
Visual Designer:
- Added Button control propert (ImageAlign) to position an image within the button.
- Corrected issues with selected Button image properties properly being reflected for the button during design time.
- Form files would have their file encoding reset to ANSI on subsequent reloading of the project.
- New Projects created with a Visual Designer template would not have the new Form located in the Normal section of the Explorer treeview.
- Fixed regression. The popup code completion intellisense now correctly displays popup list for WinFormsX global variables "Colors" and "Application".
- Added MCS_DAYSTATE style for MonthCalendar allowing the user to correctly handle the MCN_GETDAYSTATE notification in their form's AllEvents handler.
