AfxStrParseCount
Started by Petrus Vorster, June 16, 2023, 04:32:12 PM
Hi All
I want to put all available printers into a combobox.
I can easily get the list of printers using José's Cprint class, but unlike Powerbasic the list is not comma delimited, but a carriage return.
How would I do a AfxStrParseCount on that string?
Or are there other means to populate the combobox other than a little loop extracting the delimited CWSTR?
Regards,
Peter
-Regards
Peter
O, nevermind.
Chr$(13) as delimiter seem to work just fine.
-Peter
-Regards
Peter
They are separated by a carriage return and a line feed. Therefore, the correct use is to pass CHR(13, 10). CHR, not CHR$ (this is not PowerBasic).
Thank you José.
Correction made!
-Peter
-Regards
Peter
