Keyboardcodes OpenGL qt
Started by Frank Bruebach, March 13, 2024, 10:54:20 AM
Frank Bruebach
Hello all how I can make a Keyboard Code Action including to Afx and OpenGL (Here: gl/Windows/glu.bi ?
#include <GLFW/glfw3.h>
// This function is called whenever a key is pressed or released
void key_callback(GLFWwindow* window, int key, int scancode, int action, int mods)
    if (action == GLFW_PRESS)
        // Print the key code when a key is pressed
        printf("Key pressed: 0x%x\n", key);
int main()
    // Initialize GLFW
    if (!glfwInit())
        return -1;
    // Create a window
    GLFWwindow* window = glfwCreateWindow(800, 600, "My OpenGL Window", NULL, NULL);
    if (!window)
        glfwTerminate();
        return -1;
    // Make the window's context current
    glfwMakeContextCurrent(window);
    // Set the key callback function
    glfwSetKeyCallback(window, key_callback);
    // Main loop
    while (!glfwWindowShouldClose(window))
        // Render your scene here
        // Swap the front and back buffers
        glfwSwapBuffers(window);
        // Poll for events
        glfwPollEvents();
    // Terminate GLFW
    glfwTerminate();
    return 0;
This code sets up a key
Theres a sub in nehe example 03 for example with cogl.processKeyStrokes() thats the right place?
This Kind of Setup is new for me
Regards frank
Better take another example like the 08, which processes several keys:
' Processes keystrokes
' Parameters:
' * uMsg = The Windows message
' * wParam = Additional message information.
' * lParam = Additional message information.
' The contents of the wParam and lParam parameters depend on the value of the uMsg parameter.
SUB COGL.ProcessKeystrokes (BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM)
   STATIC AS BOOLEAN lp, fp, light
   SELECT CASE uMsg
      CASE WM_KEYDOWN   ' // A nonsystem key has been pressed
         SELECT CASE LOWORD(wParam)
            CASE VK_ESCAPE
               ' // Send a message to close the application
               SendMessageW m_hwnd, WM_CLOSE, 0, 0
            CASE VK_B
               blend = NOT blend
               IF blend = FALSE THEN
                  glEnable GL_BLEND
                  glDisable GL_DEPTH_TEST
                  glDisable GL_BLEND
                  glEnable GL_DEPTH_TEST
            CASE VK_L
               light = NOT light
               IF light = FALSE THEN glDisable GL_LIGHTING ELSE glEnable GL_LIGHTING
            CASE VK_F
               filter += 1
               IF filter > 2 THEN filter = 0
            CASE VK_PRIOR   ' // page up
               zoom -= 0.02
            CASE VK_NEXT   ' // page down
               zoom += 0.02
            CASE VK_UP
               xspeed -= 0.01
            CASE VK_DOWN
               xspeed += 0.01
            CASE VK_LEFT
               yspeed -= 0.01
            CASE VK_RIGHT
               yspeed += 0.01
Frank Bruebach
#2
Yes thanks Its a good example i have tested already but my question directed more to General  Keyboard Codes in OpenGL Modu
Something below
Case WM_KEYDOWN
fictive code
Print "last key pressed"
If lastkey = 1 then
Print lastkey + "  = 0x" hex(lastkey)
#macro keydown
Case 27 : ' No Action ' escape key
Case 32 : ' No Action  ' space key
#endmacro
'sorry, my mistake, I know your nehe 8 example 'already yes it's a good one but my intention was
'to print the keyboard key codes :-)
'something like that in openGL and appears on 'console too
glColor4f 1.0, 1.0, 1.0, 0.5
dim mylastkey as integer
if mylastkey ' = 1 then
  print mylastkey " = 0x" hex(mylastkey)
else
  print "(none)"
' my name
f 70=0x46
r 82=0x52
a 65=0x41
n 78=0x4e
k 75=0x4B
I have tried to built in nehe example 10 but failed
Frank Bruebach
#3
Good morning I have the solution was quite simple often WE are thinking too complicated lol
Used nehe 2 example.. If you Press a Keyboard Key the Hex value IS displayed
Solution Looks Like this one
CASE WM_KEYDOWN
         ' // Process keystrokes
           ' shows all keyboard codes :-)
            wkeystate = wParam AND &HFF ' Extract the key code
            PRINT "Last key pressed: 0x"; HEX(wkeystate)
' Microsoft Windows
' File: CW_OGL_Nehe_02
' Contents: CWindow OpenGL - NeHe lesson 2
' Translated in 2017 by José Roca. Freeware. Use at your own risk.
#define UNICODE
#INCLUDE ONCE "GL/windows/glu.bi"
USING Afx
CONST GL_WINDOWWIDTH  = 600              ' Window width
CONST GL_WINDOWHEIGHT  = 400              ' Window height
CONST GL_WindowCaption = "NeHe Lesson 2"  ' Window caption
' // Forward declarations
' OpenGL class
TYPE COGL
  Private:
      m_hDC AS HDC      ' // Device context handle
      m_hRC AS HGLRC    ' // Rendering context handle
      m_hwnd AS HWND    ' // Window handle
  Public:
      DECLARE CONSTRUCTOR (BYVAL hwnd AS HWND, BYVAL nBitsPerPel AS LONG = 32, BYVAL cDepthBits AS LONG = 24)
      DECLARE DESTRUCTOR
      DECLARE SUB SetupScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
      DECLARE SUB ResizeScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
      DECLARE SUB RenderScene
      DECLARE SUB ProcessKeystrokes (BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM)
      DECLARE SUB ProcessMouse (BYVAL uMsg AS UINT, BYVAL wKeyState AS DWORD, BYVAL x AS LONG, BYVAL y AS LONG)
      DECLARE SUB Cleanup
END TYPE
' COGL constructor
CONSTRUCTOR COGL (BYVAL hwnd AS HWND, BYVAL nBitsPerPel AS LONG = 32, BYVAL cDepthBits AS LONG = 24)
  DO  ' // Using a fake loop to avoid the use of GOTO or nested IFs/END IFs
      ' // Get the device context
      IF hwnd = NULL THEN EXIT DO
      m_hwnd = hwnd
      m_hDC = GetDC(m_hwnd)
      IF m_hDC = NULL THEN EXIT DO
      ' // Pixel format
      DIM pfd AS PIXELFORMATDESCRIPTOR
      pfd.nSize      = SIZEOF(PIXELFORMATDESCRIPTOR)
      pfd.nVersion  = 1
      pfd.dwFlags    = PFD_DRAW_TO_WINDOW OR PFD_SUPPORT_OPENGL OR PFD_DOUBLEBUFFER
      pfd.iPixelType = PFD_TYPE_RGBA
      pfd.cColorBits = nBitsPerPel
      pfd.cDepthBits = cDepthBits
      ' // Find a matching pixel format
      DIM pf AS LONG = ChoosePixelFormat(m_hDC, @pfd)
      IF pf = 0 THEN
        MessageBoxW hwnd, "Can't find a suitable pixel format", _
                    "Error", MB_OK OR MB_ICONEXCLAMATION
        EXIT DO
      ' // Set the pixel format
      IF SetPixelFormat(m_hDC, pf, @pfd) = FALSE THEN
        MessageBoxW hwnd, "Can't set the pixel format", _
        EXIT DO
      ' // Create a new OpenGL rendering context
      m_hRC = wglCreateContext(m_hDC)
      IF m_hRC = NULL THEN
        MessageBoxW hwnd, "Can't create an OpenGL rendering context", _
        EXIT DO
      ' // Make it current
      IF wglMakeCurrent(m_hDC, m_hRC) = FALSE THEN
        MessageBoxW hwnd, "Can't activate the OpenGL rendering context", _
        EXIT DO
      ' // Exit the fake loop
      EXIT DO
  LOOP
END CONSTRUCTOR
' COGL Destructor
DESTRUCTOR COGL
  ' // Release the device and rendering contexts
  wglMakeCurrent m_hDC, NULL
  ' // Make the rendering context no longer current
  wglDeleteContext m_hRC
  ' // Release the device context
  ReleaseDC m_hwnd, m_hDC
END DESTRUCTOR
' All the setup goes here
SUB COGL.SetupScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
  ' // Specify clear values for the color buffers
  glClearColor 0.0, 0.0, 0.0, 0.0
  ' // Specify the clear value for the depth buffer
  glClearDepth 1.0
  ' // Specify the value used for depth-buffer comparisons
  glDepthFunc GL_LESS
  ' // Enable depth comparisons and update the depth buffer
  ' // Select smooth shading
  glShadeModel GL_SMOOTH
' Resize the scene
SUB COGL.ResizeScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
  ' // Prevent divide by zero making height equal one
  IF nHeight = 0 THEN nHeight = 1
  ' // Reset the current viewport
  glViewport 0, 0, nWidth, nHeight
  ' // Select the projection matrix
  glMatrixMode GL_PROJECTION
  ' // Reset the projection matrix
  glLoadIdentity
  ' // Calculate the aspect ratio of the window
  gluPerspective 45.0, nWidth / nHeight, 0.1, 100.0
  ' // Select the model view matrix
  glMatrixMode GL_MODELVIEW
  ' // Reset the model view matrix
  glLoadIdentity
' Draw the scene
SUB COGL.RenderScene
  ' // Clear the screen buffer
  glClear GL_COLOR_BUFFER_BIT OR GL_DEPTH_BUFFER_BIT
  ' // Reset the view
  glLoadIdentity
  glTranslatef -1.5, 0.0, -6.0          ' Move left 1.5 units and into the screen
  glBegin GL_TRIANGLES                  ' Drawing using triangles
      glVertex3f  0.0, 1.0, 0.0          ' Top
      glVertex3f  1.0,-1.0, 0.0          ' Bottom right
      glVertex3f -1.0,-1.0, 0.0          ' Bottom left
  glEnd                                ' Finished drawing the triangle
  glTranslatef 3.0,0.0,0.0              ' Move right 3 units
  glBegin GL_QUADS                      ' Draw a quad
      glVertex3f -1.0, 1.0, 0.0          ' Top left
      glVertex3f  1.0, 1.0, 0.0          ' Top right
  glEnd                                ' Done drawing the quad
  ' // Exchange the front and back buffers
  SwapBuffers m_hdc
' Parameters:
  SELECT CASE uMsg
            CASE VK_ESCAPE
' Processes mouse clicks and movement
' Parameters:
' * wMsg      = Windows message
' * wKeyState = Indicates whether various virtual keys are down.
'              MK_CONTROL    The CTRL key is down.
'              MK_LBUTTON    The left mouse button is down.
'              MK_MBUTTON    The middle mouse button is down.
'              MK_RBUTTON    The right mouse button is down.
'              MK_SHIFT      The SHIFT key is down.
'              MK_XBUTTON1  Windows 2000/XP: The first X button is down.
'              MK_XBUTTON2  Windows 2000/XP: The second X button is down.
' * x        = x-coordinate of the cursor
' * y        = y-coordinate of the cursor
SUB COGL.ProcessMouse (BYVAL uMsg AS UINT, BYVAL wKeyState AS DWORD, BYVAL x AS LONG, BYVAL y AS LONG)
  SELECT CASE uMsg
      CASE WM_LBUTTONDOWN  ' // Left mouse button pressed
        ' // Put your code here
      CASE WM_LBUTTONUP  ' // Left mouse button releases
      CASE WM_MOUSEMOVE  ' // Mouse has been moved
' Cleanup
SUB COGL.Cleanup
  ' Insert your code here
' Main
  ' // Set process DPI aware
  AfxSetProcessDPIAware
  ' // Creates the main window
  DIM pWindow AS CWindow
  ' // Create the window
  DIM hwndMain AS HWND = pWindow.Create(NULL, GL_WindowCaption, @WndProc)
  ' // Don't erase the background
  pWindow.ClassStyle = CS_DBLCLKS
  ' // Use a black brush
  pWindow.Brush = CreateSolidBrush(BGR(0, 0, 0))
  ' // Sizes the window by setting the wanted width and height of its client area
  pWindow.SetClientSize(GL_WINDOWWIDTH, GL_WINDOWHEIGHT)
  ' // Centers the window
  pWindow.Center
  ' // Show the window
  ShowWindow hwndMain, nCmdShow
  UpdateWindow hwndMain
  ' // Message loop
  DIM uMsg AS tagMsg
  WHILE GetMessageW(@uMsg, NULL, 0, 0)
      DispatchMessageW @uMsg
  WEND
  FUNCTION = uMsg.wParam
' Main window procedure
  STATIC pCOGL AS COGL PTR  ' // Pointer to the COGL class
  DIM wkeystate as integer, action as integer
  SELECT CASE uMsg
      CASE WM_SYSCOMMAND
        ' // Disable the Windows screensaver
        IF (wParam AND &hFFF0) = SC_SCREENSAVE THEN EXIT FUNCTION
        ' // Close the window
        IF (wParam AND &hFFF0) = SC_CLOSE THEN
      CASE WM_CREATE
        ' // Initialize the new OpenGL window
        pCOGL = NEW COGL(hwnd)
        ' // Retrieve the coordinates of the window's client area
        DIM rc AS RECT
        GetClientRect hwnd, @rc
        ' // Set up the scene
        pCOGL->SetupScene rc.Right - rc.Left, rc.Bottom - rc.Top
        ' // Set the timer (using a timer to trigger redrawing allows a smoother rendering)
        SetTimer(hwnd, 1, 0, NULL)
        CASE WM_DESTROY
        ' // Kill the timer
        KillTimer(hwnd, 1)
        ' // Clean resources
        pCOGL->Cleanup
        ' // Delete the COGL class
        Delete pCOGL
        PostQuitMessage(0)
      CASE WM_TIMER
        ' // Render the scene
        pCOGL->RenderScene
      CASE WM_SIZE
        pCOGL->ResizeScene LOWORD(lParam), HIWORD(lParam)
      CASE WM_KEYDOWN
        pCOGL->ProcessKeystrokes uMsg, wParam, lParam
      CASE WM_LBUTTONDOWN, WM_LBUTTONUP, WM_MOUSEMOVE
        ' // Process mouse movements
        pCOGL->ProcessMouse uMsg, wParam, LOWORD(lParam), HIWORD(lParam)
Frank Bruebach
#4
Here's one more with keycode to ascii Convert and to unicodechar
Same example AS above
CASE WM_KEYDOWN
          print "1) Last key pressed: 0x"; HEX(wkeystate)
            'convert the keycode to ASCII
            dim keyAscii as integer = Asc(chr(wkeystate))
            'convert ascii to hex value
            dim keyhex as string = Hex$(keyAscii)
            'print hex value
            print "2) last character hex value: 0x";keyHex
    case WM_CHAR
        dim uniCodeChar as integer
        unicodechar = wParam
        dim keyhex as string = hex$(unicodechar)
          print "3) Unicode: Last character hex value: 0x";keyhex
