Menu. + Calculator
Started by Frank Bruebach, March 16, 2024, 04:58:15 PM
Frank Bruebach
Hello all
I have tried First time to adept my freebasic example (thats running fine Here See Pic below) to pWindow Style...
There are some Problem zones to fix cause I am Not very fit with using Afx.. thats relativ new stuff
' mini calculator GUI by frank bruebach, 20:06 MEZ PM, 16.03.2024
' freebasic
#define UNICODE
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "Afx/AfxGdiPlus.inc"
#INCLUDE ONCE "Afx/AfxMenu.inc"
USING Afx
' // Menu identifiers
ENUM
   IDM_UNDO = 1001   ' Undo
   IDM_REDO          ' Redo
   IDM_HOME          ' Home
   IDM_SAVE          ' Save
   IDM_EXIT          ' Exit
END ENUM
' Constants for controls
Const IDC_NUM1 = 1001
Const IDC_NUM2 = 1002
Const IDC_RESULT = 1003
Const IDC_ADD = 2001
Const IDC_SUBTRACT = 2002
Const IDC_MULTIPLY = 2003
Const IDC_DIVIDE = 2004
Const IDC_CALCULATE = 2005
' // Forward declaration
' Build the menu
FUNCTION BuildMenu () AS HMENU
   DIM hMenu AS HMENU
   DIM hPopUpMenu AS HMENU
   hMenu = CreateMenu
   hPopUpMenu = CreatePopUpMenu
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&File"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_UNDO, "&Undo" & CHR(9) & "Ctrl+U"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_REDO, "&Redo" & CHR(9) & "Ctrl+R"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_HOME, "&Home" & CHR(9) & "Ctrl+H"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVE, "&Save" & CHR(9) & "Ctrl+S"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_EXIT, "E&xit" & CHR(9) & "Alt+F4"
   FUNCTION = hMenu
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "mini Calculator GUI", @WndProc)
   pWindow.SetClientSize(400, 350)
   pWindow.Center
   ' // Add a button -> but I needed here some Radiobuttons too ;)
   pWindow.AddControl("Button", , IDCANCEL, "&Close", 280, 280, 75, 23)
   pWindow.AddControl("Edit",, IDC_NUM1, "&edit", 50, 50, 75, 23)
   pWindow.AddControl("Edit",, IDC_NUM2, "&edit", 200, 50, 75, 23)
   pWindow.AddControl("Button",, IDC_ADD, "+", 50, 100, 75, 23) 'WS_CHILD Or WS_VISIBLE Or BS_AUTORADIOBUTTON ?
   pWindow.AddControl("Button",, IDC_SUBTRACT, "-", 100, 100, 75, 23) 'WS_CHILD Or WS_VISIBLE Or BS_AUTORADIOBUTTON ?
   pWindow.AddControl("Button",, IDC_MULTIPLY, "*", 150, 100, 75, 23) 'WS_CHILD Or WS_VISIBLE Or BS_AUTORADIOBUTTON ?
   pWindow.AddControl("Button",, IDC_DIVIDE, "/", 200, 100, 75, 23) 'WS_CHILD Or WS_VISIBLE Or BS_AUTORADIOBUTTON ?
   pWindow.AddControl("Button",, IDC_CALCULATE, "=", 250, 100, 75, 23) 'WS_CHILD Or WS_VISIBLE Or BS_AUTORADIOBUTTON ?
   pWindow.AddControl("Edit",, IDC_RESULT, " ", 50, 150, 75, 23)
   ' ------------------ problem zone ----------------------------- //
   ' Set default operation to addition
   ' SendDlgItemMessage(hWnd, IDC_ADD, BM_SETCHECK, BST_CHECKED, 0)
   ' // Create the menu
   DIM hMenu AS HMENU = BuildMenu
   SetMenu pWindow.hWindow, hMenu
   ' // Add icons to the items of the File menu
   DIM hSubMenu AS HMENU = GetSubMenu(hMenu, 0)
   AfxAddIconToMenuItem(hSubMenu, 0, TRUE, AfxGdipIconFromRes(hInstance, "IDI_ARROW_LEFT_32"))
   AfxAddIconToMenuItem(hSubMenu, 1, TRUE, AfxGdipIconFromRes(hInstance, "IDI_ARROW_RIGHT_32"))
   AfxAddIconToMenuItem(hSubMenu, 2, TRUE, AfxGdipIconFromRes(hInstance, "IDI_HOME_32"))
   AfxAddIconToMenuItem(hSubMenu, 3, TRUE, AfxGdipIconFromRes(hInstance, "IDI_SAVE_32"))
dim operation As String
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
            Case IDC_ADD
                operation = "+"
            Case IDC_SUBTRACT
                operation = "-"
            Case IDC_MULTIPLY
                operation = "*"
            Case IDC_DIVIDE
                operation = "/"
            Case IDC_CALCULATE
                Dim num1 As Double
                Dim num2 As Double
                Dim result As Double
                dim as string snum1=space(21)
                dim as string snum2=space(21)
                dim as string sresult=space(21)
 '----------- problem zone ------------------------- //
                ' GetDlgItemText(hWnd, IDC_NUM1, strptr(snum1), 20)
                ' GetDlgItemText(hWnd, IDC_NUM2, strptr(snum2), 20)
                        num1= val(snum1)
                        num2= val(snum2)
                ' Perform calculation based on selected operation
                Select Case operation
                    Case "+"
                        result = num1 + num2
                    Case "-"
                        result = num1 - num2
                    Case "*"
                        result = num1 * num2
                    Case "/"
                        If num2 <> 0 Then
                            result = num1 / num2
                        Else
                            Print "Cannot divide by zero!", , "Error"
                            Exit Function
                    case Else
                    ''default addition otherwise result = zero  good!
                    sresult=str(result) ' good
                ' Display result
                ' SetDlgItemText(hWnd, IDC_RESULT, Strptr(sresult))
            CASE IDM_UNDO
               MessageBox hwnd, "Undo option clicked", "Menu", MB_OK
            CASE IDM_REDO
               MessageBox hwnd, "Redo option clicked", "Menu", MB_OK
            CASE IDM_HOME
               MessageBox hwnd, "Home option clicked", "Menu", MB_OK
            CASE IDM_SAVE
               MessageBox hwnd, "Save option clicked", "Menu", MB_OK
            CASE IDM_EXIT
        CASE WM_DESTROY
         PostQuitMessage(0)
' ends
Btw: its possible to Change the font Size of the WinFBE Editor?
Regards Frank
Hi Frank,
I fixed your code. Hopefully it is easy to understand.
' freebasic
#define UNICODE
USING Afx
ENUM
    IDM_UNDO = 5000   ' Undo
    IDM_REDO          ' Redo
    IDM_HOME          ' Home
    IDM_SAVE          ' Save
    IDM_EXIT          ' Exit
END ENUM
ENUM
    IDC_NUM1 = 1000
    IDC_NUM2
    IDC_RESULT
    IDC_ADD
    IDC_SUBTRACT
    IDC_MULTIPLY
    IDC_DIVIDE
    IDC_CALCULATE
END ENUM
' Build the menu
   DIM hMenu AS HMENU
   hMenu = CreateMenu
   FUNCTION = hMenu
   pWindow.Center
   pWindow.AddControl("Edit",, IDC_NUM1, "", 50, 50, 75, 23)
   pWindow.AddControl("Edit",, IDC_NUM2, "", 200, 50, 75, 23)
   pWindow.AddControl("RADIOBUTTON",, IDC_ADD, "+", 50, 100, 30, 23, WS_GROUP)
   pWindow.AddControl("RADIOBUTTON",, IDC_SUBTRACT, "-", 100, 100, 30, 23)
   pWindow.AddControl("RADIOBUTTON",, IDC_MULTIPLY, "*", 150, 100, 30, 23)
   pWindow.AddControl("RADIOBUTTON",, IDC_DIVIDE, "/", 200, 100, 30, 23)
   pWindow.AddControl("BUTTON",, IDC_CALCULATE, "=", 250, 100, 75, 23)
   pWindow.AddControl("Edit",, IDC_RESULT, "", 50, 150, 75, 23)
   CheckRadioButton(pWindow.hWindow, IDC_ADD, IDC_DIVIDE, IDC_ADD)
   SetFocus GetDlgItem(pWindow.hWindow, IDC_NUM1)
     SELECT CASE uMsg
         CASE WM_COMMAND
                     CASE IDCANCEL
                     CASE IDC_CALCULATE
                         dim as double num1 = val(AfxGetWindowText(GetDlgItem(hwnd, IDC_NUM1)))
                         dim as double num2 = val(AfxGetWindowText(GetDlgItem(hwnd, IDC_NUM2)))
                         Dim as double result
                         if Button_GetCheck(GetDlgItem(hwnd,IDC_ADD)) = BST_CHECKED then
                         if Button_GetCheck(GetDlgItem(hwnd,IDC_SUBTRACT)) = BST_CHECKED then
                         if Button_GetCheck(GetDlgItem(hwnd,IDC_MULTIPLY)) = BST_CHECKED then
                         if Button_GetCheck(GetDlgItem(hwnd,IDC_DIVIDE)) = BST_CHECKED then
                             If num2 <> 0 Then
                             Else
                                 Exit Function
                        AfxSetWindowText(GetDlgItem(hwnd, IDC_RESULT), str(result))
                     CASE IDM_UNDO
                     CASE IDM_REDO
                     CASE IDM_HOME
                     CASE IDM_SAVE
                     CASE IDM_EXIT
        CASE WM_DESTROY
         PostQuitMessage(0)
QuoteBtw: its possible to Change the font Size of the WinFBE Editor?
"File", "Preferences", "Environment Setup"  (or simply press F7)
Select "Themes and Fonts"
You can change the font, font size, and the spacing between the lines.
Frank Bruebach
#2
Many thanks Paul !
QuoteI fixed your code. Hopefully it is easy to understand.
I See all Changes and understand new Afx Features... I am Glad its working :)
Thats my First gui SDK example with AFx beside openGl and I Like the WinFBE Editor too ITS a great Job and hard Work I can Imagine...
Nice Weekend Bye
, frank
