WinFBE 3.2.0 (May 29, 2025)
Started by Paul Squires, June 02, 2025, 08:59:29 AM
Download link:  https://github.com/PaulSquires/WinFBE/releases
Version 3.2.0 (May 29, 2025)
- Compiling .bas Modules now honors Project flags set for -g, -e, -ex, and -exx allowing debug information
to be compiled into the .bas module object files.
- Fixed problem with editor not loading Project files on startup if the "Restore previous session files on startup" option is checked.
- Fixed problem whereby selecting "Remove from Project" from right-click popup menu in File Explorer could unintentionally remove
additional document(s) in the project.
- Fixed parsing problem whereby embedded TODO identifiers were missed when occurring at end of DIM, SUB, or FUNCTION lines.
- Updated included FreeBasic Compiler to version 1.10.1 (located in toolchain: "FreeBASIC-1.10.1-winlibs-gcc-9.3.0").
- Updated to latest FreeBasic CHM Help file.
