Error with C backend
Started by docroger, July 31, 2025, 06:33:48 AM
docroger
Hello José, me again...
With the last version afxnova (with tabs) : i cant compile with gcc :
Quoteerror: '_ZTSN14AFX_IDISPATCH_E' undeclared here (not in a function); did you mean '_ZN14AFX_IDISPATCH_C1Ev'?
 3274 | static struct $8fb_RTTI$ _ZTSN7AFXNOVA16AFX_IDICTIONARY_E = { (void*)0ull, (char*)"N7AFXNOVA16AFX_IDICTIONARY_E", &_ZTSN14AFX_IDISPATCH_E };
      |        _ZN14AFX_IDISPATCH_C1Ev
With GAS64 : no error.
My app is broken.
PS : if i comment include afxnova/cinifile.inc : the code compile fine with GCC...
Works in my computer. I don't know what this cryptic message means.
You can't compile what?
docroger
My app use AFXnova DDT + Cinifile : compile well with prec version AFXnova.
With the latest : compile with GAS64 but error with GCC.
If i comment then include cinifile on my app : compile with GCC.
Without Cinifile no problem.
The error message is linker message.
docroger
With the latest afxnova on github :
This code dont compile with cbackend (x64) with error :
3103 | static struct $8fb_RTTI$ _ZTSN7AFXNOVA16AFX_IDICTIONARY_E = { (void*)0ull, (char*)"N7AFXNOVA16AFX_IDICTIONARY_E", &_ZTSN14AFX_IDISPATCH_E };
compiling C failed: 'E:\perso\dev\freebasic\tiko-1.2.3\Toolchains\FreeBASIC-1.10.1-winlibs-gcc-9.3.0\bin\win64\gcc.exe' terminated with exit code 1
'#TEMPLATE DDT Dialog with a button
#define UNICODE
#define _WIN32_WINNT &h0602
#include once "AfxNova/DDT.inc"
'comment this line >>> compile fine
#include once "afxnova/cinifile.inc"
USING AfxNova
   END wWinMain(GetModuleHandleW(NULL), NULL, wCommand(), SW_NORMAL)
DECLARE FUNCTION DlgProc (BYVAL hDlg AS HWND, BYVAL uMsg AS DWORD, BYVAL wParam AS DWORD, BYVAL lParam AS LPARAM) AS INT_PTR
CONST IDC_OK = 1001
' Main
   ' // Set process DPI aware
   AfxEnableVisualStyles
   ' // Create a new dialog using dialog units
   DIM hDlg AS HWND = DialogNew(0, "DDT Dialog with a button", 50, 50, 175, 65, WS_OVERLAPPEDWINDOW OR DS_CENTER)
   ' // Add a button to the dialog
   ControlAddButton, hDlg, IDC_OK, "&Ok", 105, 40, 50, 12, BS_DEFPUSHBUTTON
   ' // Anchor the button to the bottom and the right side of the dialog
   ControlAnchor(hDlg, IDC_OK, AFX_ANCHOR_BOTTOM_RIGHT)
   ' // Display and activate the dialog as modal
   DialogShowModal(hDlg, @DlgProc)
   RETURN DialogEndResult(hDlg)
' Dialog callback procedure
   SELECT CASE uMsg
      CASE WM_INITDIALOG
         RETURN TRUE
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN
                  SendMessageW hDlg, WM_CLOSE, 0, 0
            CASE IDC_OK
               MsgBox("OK button pressed", MB_ICONEXCLAMATION OR MB_TASKMODAL, "Message")
      CASE WM_CLOSE
         ' // End the application
         DialogEnd(hDlg)
   RETURN FALSE
That's strange. I am also getting that same error when trying to compile with gcc. Hopefully it is not a Tiko Editor problem with the compiling of the source code. I will have to try compiling it with a different editor (or command line) just to be sure.
Found the problem. Remove NAMESPACE AfxNova and END NAMESPACE in AfxScrRun.bi
Never had tried gcc before. Optimizing for size reduces the size of the executable very much.
Ah, that's good news that you found the cause of the problem!
