AfxSetWindowText
Started by Paul Squires, August 01, 2025, 08:26:21 PM
AfxNova does not have AfxSetWindowText whereas WinAfx does.
Maybe you can add it back to AfxWin.inc.
I am creating a new project using AfxNova.
I can add it if you want, but you can use the Windows API SetWindowText, that does exactly the same.
Quote from: José Roca on August 01, 2025, 08:45:14 PMI can add it if you want, but you can use the Windows API SetWindowText, that does exactly the same.
Yes, of course, but for the sake of symmetry it makes sense to have it included. AfxGetWindowText and AfxSetWindowText.
Done. All that is needed is #define AfxSetWindowText SetWindowTextW
