OpenGl Nehe 5 + coordinate system
Started by Frank Bruebach, August 07, 2025, 05:32:21 PM
Frank Bruebach
Tiko Editor, Nehe 5 example, afxNova
OpenGL test
Hello, I have build in a coordinate system Just for fun. Works all fine Here. No need for using fbgfx library ;-) the Cube rotates with coordinate system.
Must Split the Code example cause Code Editor Had reached its Limit.
' Microsoft Windows
' File: CW_GL_Nehe_05
' Contents: CWindow OpenGL - NeHe lesson 5
' Translated in 2025 by José Roca. Freeware. Use at your own risk.
' nehe 5, openGL, Frank bruebach, 07-08-2025, build-in a coordinatesystem
' tiko editor using
#define UNICODE
#INCLUDE ONCE "AfxNova/CWindow.inc"
#INCLUDE ONCE "GL/windows/glu.bi"
USING AfxNova
CONST GL_WINDOWWIDTH  = 600              ' Window width
CONST GL_WINDOWHEIGHT  = 400              ' Window height
CONST GL_WindowCaption = "NeHe Lesson 5 + Coordinate-System"  ' Window caption
DECLARE SUB Coordinatesystem(was AS STRING, TxtPara AS STRING, Para1 AS SINGLE, Para2 AS SINGLE, Para3 AS SINGLE)
DECLARE SUB Object1()
DECLARE SUB movedPoints()
  END wWinMain(GetModuleHandleW(NULL), NULL, wCOMMAND(), SW_NORMAL)
' // Forward declarations
' OpenGL class
TYPE COGL
  Private:
      m_hDC AS HDC      ' // Device context handle
      m_hRC AS HGLRC    ' // Rendering context handle
      m_hwnd AS HWND    ' // Window handle
      rtri AS SINGLE
      rquad AS SINGLE
  Public:
      DECLARE CONSTRUCTOR (BYVAL hwnd AS HWND, BYVAL nBitsPerPel AS LONG = 32, BYVAL cDepthBits AS LONG = 24)
      DECLARE DESTRUCTOR
      DECLARE SUB SetupScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
      DECLARE SUB ResizeScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
      DECLARE SUB RenderScene
      DECLARE SUB ProcessKeystrokes (BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM)
      DECLARE SUB ProcessMouse (BYVAL uMsg AS UINT, BYVAL wKeyState AS DWORD, BYVAL x AS LONG, BYVAL y AS LONG)
      DECLARE SUB Cleanup
END TYPE
' COGL constructor
CONSTRUCTOR COGL (BYVAL hwnd AS HWND, BYVAL nBitsPerPel AS LONG = 32, BYVAL cDepthBits AS LONG = 24)
  DO  ' // Using a fake loop to avoid the use of GOTO or nested IFs/END IFs
      ' // Get the device context
      IF hwnd = NULL THEN EXIT DO
      m_hwnd = hwnd
      m_hDC = GetDC(m_hwnd)
      IF m_hDC = NULL THEN EXIT DO
      ' // Pixel format
      DIM pfd AS PIXELFORMATDESCRIPTOR
      pfd.nSize      = SIZEOF(PIXELFORMATDESCRIPTOR)
      pfd.nVersion  = 1
      pfd.dwFlags    = PFD_DRAW_TO_WINDOW OR PFD_SUPPORT_OPENGL OR PFD_DOUBLEBUFFER
      pfd.iPixelType = PFD_TYPE_RGBA
      pfd.cColorBits = nBitsPerPel
      pfd.cDepthBits = cDepthBits
      ' // Find a matching pixel format
      DIM pf AS LONG = ChoosePixelFormat(m_hDC, @pfd)
      IF pf = 0 THEN
        MessageBoxW hwnd, "Can't find a suitable pixel format", _
                    "Error", MB_OK OR MB_ICONEXCLAMATION
        EXIT DO
      ' // Set the pixel format
      IF SetPixelFormat(m_hDC, pf, @pfd) = FALSE THEN
        MessageBoxW hwnd, "Can't set the pixel format", _
        EXIT DO
      ' // Create a new OpenGL rendering context
      m_hRC = wglCreateContext(m_hDC)
      IF m_hRC = NULL THEN
        MessageBoxW hwnd, "Can't create an OpenGL rendering context", _
        EXIT DO
      ' // Make it current
      IF wglMakeCurrent(m_hDC, m_hRC) = FALSE THEN
        MessageBoxW hwnd, "Can't activate the OpenGL rendering context", _
        EXIT DO
      ' // Exit the fake loop
      EXIT DO
  LOOP
END CONSTRUCTOR
' COGL Destructor
DESTRUCTOR COGL
  ' // Release the device and rendering contexts
  wglMakeCurrent m_hDC, NULL
  ' // Make the rendering context no longer current
  wglDeleteContext m_hRC
  ' // Release the device context
  ReleaseDC m_hwnd, m_hDC
END DESTRUCTOR
' All the setup goes here
SUB COGL.SetupScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
  ' // Specify clear values for the color buffers
  glClearColor 0.0, 0.0, 0.0, 0.0
  ' // Specify the clear value for the depth buffer
  glClearDepth 1.0
  ' // Specify the value used for depth-buffer comparisons
  glDepthFunc GL_LESS
  ' // Enable depth comparisons and update the depth buffer
  glEnable GL_DEPTH_TEST
  ' // Select smooth shading
  glShadeModel GL_SMOOTH
' Resize the scene
SUB COGL.ResizeScene (BYVAL nWidth AS LONG, BYVAL nHeight AS LONG)
  ' // Prevent divide by zero making height equal one
  IF nHeight = 0 THEN nHeight = 1
  ' // Reset the current viewport
  glViewport 0, 0, nWidth, nHeight
  ' // Select the projection matrix
  glMatrixMode GL_PROJECTION
  ' // Reset the projection matrix
  glLoadIdentity
  ' // Calculate the aspect ratio of the window
  gluPerspective 45.0, nWidth / nHeight, 0.1, 100.0
  ' // Select the model view matrix
  glMatrixMode GL_MODELVIEW
  ' // Reset the model view matrix
  glLoadIdentity
' Draw the scene
SUB COGL.RenderScene
  ' // Clear the screen buffer
  glClear GL_COLOR_BUFFER_BIT OR GL_DEPTH_BUFFER_BIT
  ' // Reset the view
  glLoadIdentity
  glTranslatef -1.5, 0.0, -6.0          ' Move left 1.5 units and into the screen
  glRotatef rtri, 0.0, 1.0, 0.0          ' Rotate the triangle on the Y axis
  glBegin GL_TRIANGLES
      ' Front
      glColor3f  1.0,  0.0,  0.0        ' Red
      glVertex3f  0.0,  1.0,  0.0        ' Top of triangle (Front)
      glColor3f  0.0,  1.0,  0.0        ' Green
      glVertex3f -1.0, -1.0,  1.0        ' Left of triangle (Front)
      glColor3f  0.0,  0.0,  1.0        ' Blue
      glVertex3f  1.0, -1.0,  1.0        ' Right of triangle (Front)
      ' Right
      glVertex3f  0.0,  1.0,  0.0        ' Top of triangle (Right)
      glVertex3f  1.0, -1.0,  1.0        ' Left of triangle (Right)
      glVertex3f  1.0, -1.0, -1.0        ' Right of triangle (Right)
      ' Back
      glVertex3f  0.0,  1.0,  0.0        ' Top of triangle (Back)
      glVertex3f  1.0, -1.0, -1.0        ' Left of triangle (Back)
      glVertex3f -1.0, -1.0, -1.0        ' Right of triangle (Back)
      ' Left
      glVertex3f  0.0,  1.0,  0.0        ' Top of triangle (Left)
      glVertex3f -1.0, -1.0, -1.0        ' Left of triangle (Left)
      glVertex3f -1.0, -1.0,  1.0        ' Right of triangle (Left)
  glEnd
  glLoadIdentity
  glTranslatef 1.5, 0.0, -7.0            ' Move right 1.5 units and into the screen
  glRotatef rquad, 1.0, 1.0, 1.0        ' Rotate the quad on the X axis
  glBegin GL_QUADS
      glColor3f  0.0,  1.0,  0.0        ' Set the color to green
      glVertex3f  1.0,  1.0, -1.0        ' Top right of the quad (Top)
      glVertex3f -1.0,  1.0, -1.0        ' Top left of the quad (Top)
      glVertex3f -1.0,  1.0,  1.0        ' Bottom left of the quad (Top)
      glVertex3f  1.0,  1.0,  1.0        ' Bottom right of the quad (Top)
      glColor3f  1.0,  0.5,  0.0        ' Set the color to orange
      glVertex3f  1.0, -1.0,  1.0        ' Top right of the quad (Bottom)
      glVertex3f -1.0, -1.0,  1.0        ' Top left of the quad (Bottom)
      glVertex3f -1.0, -1.0, -1.0        ' Bottom left of the quad (Bottom)
      glVertex3f  1.0, -1.0, -1.0        ' Bottom right of the quad (Bottom)
      glColor3f  1.0,  0.0,  0.0        ' Set the color to red
      glVertex3f  1.0,  1.0,  1.0        ' Top right of the quad (Front)
      glVertex3f -1.0,  1.0,  1.0        ' Top left of the quad (Front)
      glVertex3f -1.0, -1.0,  1.0        ' Bottom left of the quad (Front)
      glVertex3f  1.0, -1.0,  1.0        ' Bottom right of the quad (Front)
      glColor3f  1.0,  1.0,  0.0        ' Set the color to yellow
      glVertex3f  1.0, -1.0, -1.0        ' Top right of the quad (Back)
      glVertex3f -1.0, -1.0, -1.0        ' Top left of the quad (Back)
      glVertex3f -1.0,  1.0, -1.0        ' Bottom left of the quad (Back)
      glVertex3f  1.0,  1.0, -1.0        ' Bottom right of the quad (Back)
      glColor3f  0.0,  0.0,  1.0        ' Set the color to blue
      glVertex3f -1.0,  1.0,  1.0        ' Top right of the quad (Left)
      glVertex3f -1.0,  1.0, -1.0        ' Top left of the quad (Left)
      glVertex3f -1.0, -1.0, -1.0        ' Bottom left of the quad (Left)
      glVertex3f -1.0, -1.0,  1.0        ' Bottom right of the quad (Left)
      glColor3f  1.0,  0.0,  1.0        ' Set the color to violet
      glVertex3f  1.0,  1.0, -1.0        ' Top right of the quad (Right)
      glVertex3f  1.0,  1.0,  1.0        ' Top left of the quad (Right)
      glVertex3f  1.0, -1.0,  1.0        ' Bottom left of the quad (Right)
      glVertex3f  1.0, -1.0, -1.0        ' Bottom right of the quad (Right)
  glEnd
  rtri = rtri + 0.2                      ' Increase the rotation variable for the triangle
  rquad = rquad - 0.15                  ' Decrease the rotation variable for the quad
  'object1()
  Coordinatesystem("", "", 0, 0, 0) ' go
  ' // Exchange the front and back buffers
  SwapBuffers m_hdc
' Processes keystrokes
' Parameters:
' * uMsg = The Windows message
' * wParam = Additional message information.
' * lParam = Additional message information.
' The contents of the wParam and lParam parameters depend on the value of the uMsg parameter.
SUB COGL.ProcessKeystrokes (BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM)
  SELECT CASE uMsg
      CASE WM_KEYDOWN  ' // A nonsystem key has been pressed
        SELECT CASE LOWORD(wParam)
            CASE VK_ESCAPE
              ' // Send a message to close the application
              SendMessageW m_hwnd, WM_CLOSE, 0, 0
' Processes mouse clicks and movement
' Parameters:
' * wMsg      = Windows message
' * wKeyState = Indicates whether various virtual keys are down.
'              MK_CONTROL    The CTRL key is down.
'              MK_LBUTTON    The left mouse button is down.
'              MK_MBUTTON    The middle mouse button is down.
'              MK_RBUTTON    The right mouse button is down.
'              MK_SHIFT      The SHIFT key is down.
'              MK_XBUTTON1  Windows 2000/XP: The first X button is down.
'              MK_XBUTTON2  Windows 2000/XP: The second X button is down.
' * x        = x-coordinate of the cursor
' * y        = y-coordinate of the cursor
SUB COGL.ProcessMouse (BYVAL uMsg AS UINT, BYVAL wKeyState AS DWORD, BYVAL x AS LONG, BYVAL y AS LONG)
  SELECT CASE uMsg
      CASE WM_LBUTTONDOWN  ' // Left mouse button pressed
        ' // Put your code here
      CASE WM_LBUTTONUP  ' // Left mouse button releases
      CASE WM_MOUSEMOVE  ' // Mouse has been moved
' Cleanup
SUB COGL.Cleanup
  ' Insert your code here
' Main
  ' // Set process DPI aware
  ' // Creates the main window
  DIM pWindow AS CWindow
  ' // Create the window
  DIM hwndMain AS HWND = pWindow.Create(NULL, GL_WindowCaption, @WndProc)
  ' // Don't erase the background
  pWindow.ClassStyle = CS_DBLCLKS
  ' // Use a black brush
  pWindow.Brush = CreateSolidBrush(BGR(0, 0, 0))
  ' // Sizes the window by setting the wanted width and height of its client area
  pWindow.SetClientSize(GL_WINDOWWIDTH, GL_WINDOWHEIGHT)
  ' // Centers the window
  pWindow.Center
  ' // Show the window
  ShowWindow hwndMain, nCmdShow
  UpdateWindow hwndMain
  ' // Message loop
  DIM uMsg AS tagMsg
  WHILE GetMessageW(@uMsg, NULL, 0, 0)
      DispatchMessageW @uMsg
  WEND
  FUNCTION = uMsg.wParam
' Main window procedure
  STATIC pCOGL AS COGL PTR  ' // Pointer to the COGL class
  SELECT CASE uMsg
      CASE WM_SYSCOMMAND
        ' // Disable the Windows screensaver
        IF (wParam AND &hFFF0) = SC_SCREENSAVE THEN EXIT FUNCTION
        ' // Close the window
        IF (wParam AND &hFFF0) = SC_CLOSE THEN
      CASE WM_CREATE
        ' // Initialize the new OpenGL window
        pCOGL = NEW COGL(hwnd)
        ' // Retrieve the coordinates of the window's client area
        DIM rc AS RECT
        GetClientRect hwnd, @rc
        ' // Set up the scene
        pCOGL->SetupScene rc.Right - rc.Left, rc.Bottom - rc.Top
        ' // Set the timer (using a timer to trigger redrawing allows a smoother rendering)
        SetTimer(hwnd, 1, 0, NULL)
        CASE WM_DESTROY
        ' // Kill the timer
        KillTimer(hwnd, 1)
        ' // Clean resources
        pCOGL->Cleanup
        ' // Delete the COGL class
        Delete pCOGL
        PostQuitMessage(0)
      CASE WM_TIMER
        ' // Render the scene
        pCOGL->RenderScene
      CASE WM_SIZE
        pCOGL->ResizeScene LOWORD(lParam), HIWORD(lParam)
      CASE WM_KEYDOWN
        ' // Process keystrokes
        pCOGL->ProcessKeystrokes uMsg, wParam, lParam
      CASE WM_LBUTTONDOWN, WM_LBUTTONUP, WM_MOUSEMOVE
        ' // Process mouse movements
        pCOGL->ProcessMouse uMsg, wParam, LOWORD(lParam), HIWORD(lParam)
Frank Bruebach
Parte two
SUB movedPoints()
  STATIC AS SINGLE page, height, depth
  page=page + 0.01
  IF page > 3 THEN page = -3    :
  glTranslatef page, 0, -6        :
  Object1()
SUB Object1()
  glBegin GL_POINTS
    glVertex3f  1,  1, 0
    glVertex3f  -1, -1, 0
  glEnd
  DIM AS INTEGER Zaehler
'glPushMatrix
        glBegin GL_LINES:
        glColor3f 1.0, 1.0, 1.0        :
        FOR Zaehler = 1 TO 6 :
            'X-AXES
            glVertex3f  Zaehler+Para1,  0.2+Para2,  0.0+Para3 :
            glVertex3f  Zaehler+Para1, -0.2+Para2,  0.0+Para3 :
            glVertex3f  Zaehler+Para1,  0.0+Para2,  0.2+Para3 :
            glVertex3f  Zaehler+Para1,  0.0+Para2, -0.2+Para3 :
            'Y-AXES
            glVertex3f  0.2+Para1, Zaehler+Para2,  0.0+Para3 :
            glVertex3f -0.2+Para1, Zaehler+Para2,  0.0+Para3 :
            glVertex3f  0.0+Para1, Zaehler+Para2,  0.2+Para3 :
            glVertex3f  0.0+Para1, Zaehler+Para2, -0.2+Para3 :
            'Z-AXES
            glVertex3f  0.2+Para1,  0.0+Para2, Zaehler+Para3 :
            glVertex3f -0.2+Para1,  0.0+Para2, Zaehler+Para3 :
            glVertex3f  0.0+Para1,  0.2+Para2,  Zaehler+Para3 :
            glVertex3f  0.0+Para1, -0.2+Para2,  Zaehler+Para3 :
        NEXT Zaehler
        glColor3f 0.0, 0.0, 0.0        :
        FOR Zaehler = -6 TO -1 :
        'X-AXES
            'Y-AXES
            'Z-AXES
        NEXT Zaehler
        ' all together axes
        'X-AXES
        glColor3f 1.0, 0.0, 0.0        :' X = red
        glVertex3f  -6.0+Para1, 0+Para2, 0+Para3
        glVertex3f  +6.0+Para1, 0+Para2, 0+Para3
        'Y-AXES
        glColor3f 0.0, 1.0, 0.0        :' Y = green
        glVertex3f  0+Para1, -6.0+Para2, 0+Para3
        glVertex3f  0+Para1, +6.0+Para2, 0+Para3
        'Z-AXES
        glColor3f 0.0, 0.0, 1.0        :' Ze = blue
        glVertex3f  0+Para1, 0+Para2, -6.0+Para3
        glVertex3f  0+Para1, 0+Para2, +6.0+Para3
      glEnd
'glPopMatrix
Frank Bruebach
hello again..
afxnova, openGL, tiko editor.
perhaps somebody is interested in.. made a simple coordinate cross and you
can move it by arrows and pageup pagedown key
' freebasic, afxNova, openGL: coordinate cross, moving, 09-08-2025 by frank brubach
' Use ESC key to quit
' PgUp key and PgDn key to Zoom in and out
' UpArrow, DnArrow, RightArrow, Left Arrow to change rotate speed of coordinate cross
#define UNICODE
#INCLUDE ONCE "AfxNova/AfxGdiplus.inc"
USING AfxNova
CONST GL_WINDOWWIDTH  = 800
CONST GL_WINDOWHEIGHT  = 600
CONST GL_WindowCaption = "Coordinate cross & moving via arrows"
                          BYVAL pwsszCmdLine AS WSTRING PTR, _
' OpenGL class
TYPE COGL
  Private:
      xrot AS SINGLE
      yrot AS SINGLE
      zoom AS SINGLE
      filter AS LONG
      xspeed AS SINGLE
      yspeed AS SINGLE
  Public:
      DECLARE DESTRUCTOR
      DECLARE SUB Cleanup
END TYPE
' COGL constructor
      m_hwnd = hwnd
      ' // Pixel format
      pfd.nVersion  = 1
      IF pf = 0 THEN
        EXIT DO
        EXIT DO
        EXIT DO
        EXIT DO
      EXIT DO
  LOOP
END CONSTRUCTOR
' COGL Destructor
DESTRUCTOR COGL
END DESTRUCTOR
  glClearDepth 1.0
  glDepthFunc GL_LESS
  zoom = -5.0
' Resize the scene
  glLoadIdentity
  glLoadIdentity
' Draw the scene
  ' // Reset the view
  glLoadIdentity
  glTranslatef 0.0, 0.0, zoom
  glRotatef xrot, 1.0, 0.0, 0.0
  glRotatef yrot, 0.0, 1.0, 0.0
  ' -- coordinatesystem here included ---------------------------------------------------------
  dim as integer counter
  dim as string TxtPara
  dim as single Para1, Para2, Para3
'glPushMatrix
        glBegin GL_LINES:
        FOR Counter = 1 TO 6 :
            'X-AXES
            glVertex3f  counter+Para1,  0.2+Para2,  0.0+Para3 :
            glVertex3f  counter+Para1, -0.2+Para2,  0.0+Para3 :
            glVertex3f  counter+Para1,  0.0+Para2,  0.2+Para3 :
            glVertex3f  counter+Para1,  0.0+Para2, -0.2+Para3 :
            'Y-AXES
            glVertex3f  0.2+Para1, counter+Para2,  0.0+Para3 :
            glVertex3f -0.2+Para1, counter+Para2,  0.0+Para3 :
            glVertex3f  0.0+Para1, counter+Para2,  0.2+Para3 :
            glVertex3f  0.0+Para1, counter+Para2, -0.2+Para3 :
            'Z-AXES
            glVertex3f  0.2+Para1,  0.0+Para2, counter+Para3 :
            glVertex3f -0.2+Para1,  0.0+Para2, counter+Para3 :
            glVertex3f  0.0+Para1,  0.2+Para2,  counter+Para3 :
            glVertex3f  0.0+Para1, -0.2+Para2,  counter+Para3 :
        NEXT counter
        FOR counter = -6 TO -1
        'X-AXES
            'Y-AXES
            'Z-AXES
        NEXT counter
        ' all together axes
        'X-AXES
        'Y-AXES
        'Z-AXES
      glEnd
  xrot = xrot + xspeed
  yrot = yrot + yspeed
  SwapBuffers m_hdc
  STATIC AS BOOLEAN lp, fp, light
  SELECT CASE uMsg
            CASE VK_ESCAPE
            CASE VK_UP
              xspeed -= 0.01
            CASE VK_DOWN
              xspeed += 0.01
            CASE VK_LEFT
              yspeed -= 0.01
            CASE VK_RIGHT
              yspeed += 0.01
            CASE VK_PRIOR  ' // page up
              zoom -= 0.02
            CASE VK_NEXT  ' // page down
              zoom += 0.02
  SELECT CASE uMsg
' Cleanup
SUB COGL.Cleanup
  pWindow.Center
  ' // Message loop
  DIM uMsg AS tagMsg
  WEND
  SELECT CASE uMsg
      CASE WM_SYSCOMMAND
      CASE WM_CREATE
        DIM rc AS RECT
        CASE WM_DESTROY
        ' // Kill the timer
        KillTimer(hwnd, 1)
        pCOGL->Cleanup
        Delete pCOGL
        PostQuitMessage(0)
      CASE WM_TIMER
        pCOGL->RenderScene
      CASE WM_SIZE
      CASE WM_KEYDOWN
