Tiko 1.2.5 glitches
Started by docroger, September 16, 2025, 10:42:37 AM
docroger
Hello Paul,
Here is some glitches with Tiko (windows 10 Pro, x64) :
Hope you can see the gif animation in the forum, its difficult to explain with words.
Thanks for the report. I have seen that phantom gray rectangle glitch (from your first gif) before and have been working over the months to prevent it. It is an artifact from the main menubar when the editor comes in and out of focus. I will make an effort to prevent it. I will also look into the second gif.
Pretty sure that I have now fixed these problems. The fixes will be in the next official release but if you ant to try them out early then you can download the latest exe from the development branch:
https://github.com/PaulSquires/tiko/blob/development/tiko.exe
Simply overwrite your existing tiko.exe with that one that you download.
docroger
Hello Paul,
Very nice ! Good catch ! All works well.
Good job !
Tested on Win 11 Pro
