Mdi example question
Started by Frank Bruebach, December 22, 2025, 02:45:10 PM
Frank Bruebach
hello jose, it's possible to translate this mdi framework demo to afxnova?
thanks, frank
' Microsoft Windows
' File: CW_MDIDemo.pbtpl
' Contents: CWindow MDI Framework Demo
' Copyright (c) 2016 José Roca. Freeware. Use at your own risk.
#define UNICODE
#define USEMDI
USING Afx
' // Edit control identifier
CONST IDC_EDIT = 101
' // Menu identifiers
ENUM
   IDM_NEW = 1001     ' New file
   IDM_OPEN           ' Open file...
   IDM_SAVE           ' Save file
   IDM_SAVEAS         ' Save file as...
   IDM_EXIT           ' Exit
   IDM_UNDO = 2001    ' Undo
   IDM_CUT            ' Cut
   IDM_COPY           ' Copy
   IDM_PASTE          ' Paste
   IDM_TILEH = 3001   ' Tile hosizontal
   IDM_TILEV          ' Tile vertical
   IDM_CASCADE        ' Cascade
   IDM_ARRANGE        ' Arrange icons
   IDM_CLOSE          ' Close
   IDM_CLOSEALL       ' Close all
END ENUM
' // Forward declarations
DECLARE FUNCTION MDIWindowProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
' Build the menu
FUNCTION BuildMenu () AS HMENU
   DIM hMenu AS HMENU
   DIM hPopUpMenu AS HMENU
   hMenu = CreateMenu
   hPopUpMenu = CreatePopUpMenu
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&File"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_NEW, "&New" & CHR(9) & "Ctrl+N"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_OPEN, "&Open..." & CHR(9) & "Ctrl+O"
         AppendMenuW hPopUpMenu, MF_SEPARATOR, 0, ""
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVE, "&Save" & CHR(9) & "Ctrl+S"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVEAS, "Save &As..."
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_EXIT, "E&xit" & CHR(9) & "Alt+F4"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Edit"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_UNDO, "&Undo" & CHR(9) & "Ctrl+Z"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CUT, "Cu&t" & CHR(9) & "Ctrl+X"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_COPY, "&Copy" & CHR(9) & "Ctrl+C"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_PASTE, "&Paste" & CHR(9) & "Ctrl+V"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Window"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEH, "&Tile Horizontal"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEV, "Tile &Vertical"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CASCADE, "Ca&scade"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_ARRANGE, "&Arrange &Icons"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSE, "&Close" & CHR(9) & "Ctrl+F4"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSEALL, "Close &All"
   FUNCTION = hMenu
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "MDI with CWindow", @WndProc)
   ' // Change the window style to avoid flicker
   pWindow.ClassStyle = CS_DBLCLKS
   ' // Set the client size
   pWindow.SetClientSize 650, 400
   ' // Center the window
   pWindow.Center
   ' // Create a menu
   DIM hMenu AS HMENU
   hMenu = BuildMenu
   SetMenu pWindow.hWindow, hMenu
   '// Create a MDI client child window
   DIM hwindowMenu AS HMENU
   hwindowMenu = GetSubMenu(hMenu, 2)
   pWindow.CreateMDIWindow(101, 0, 0, 0, 0, 0, 0, hwindowMenu, @MDIWindowProc)
   STATIC hwndClient AS HWND    ' // Handle of the MDI client window
   DIM hwndActive AS HWND       ' // Active window
   DIM ptnmhdr AS NMHDR PTR     ' // Information about a notification message
   DIM hMdi AS HWND             ' // MDI child window handle
   STATIC nIdx AS LONG          ' // Counter
   STATIC pWindow AS CWindow PTR
   FUNCTION = 0
   ' // Retrieve the MDI client window handle
   IF hwndClient = NULL AND pWindow <> NULL THEN hwndClient = pWindow->hwndClient
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
         ' // Retrieve a reference to the CWindow class from the CREATESTRUCT structure
         pWindow = AfxCWindowPtr(lParam)
      CASE WM_COMMAND
            CASE IDCANCEL
            ' // New window
            CASE IDM_NEW
               IF hwndClient THEN
                  nIdx += 1
                  DIM mdi AS MDICREATESTRUCTW, dwStyle AS DWORD
                  IF IsZoomed(CAST(HWND, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))) THEN dwStyle = WS_MAXIMIZE
                  hMdi = CreateWindowExW(WS_EX_MDICHILD OR WS_EX_CLIENTEDGE, "FBFrameClass", "", _
                           dwStyle, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, _
                           hwndClient, NULL, CAST(HANDLE, GetWindowLongPtrW(hwndClient, GWLP_HINSTANCE)), NULL)
                  SetWindowTextW hMdi, "MDI Child Window " & WSTR(nIdx)
            ' // Tile horizontally
            CASE IDM_TILEH
               IF hwndClient THEN SendMessageW hwndClient, WM_MDITILE, MDITILE_HORIZONTAL, 0
            ' // Tile vertically
            CASE IDM_TILEV
               IF hwndClient THEN SendMessageW hwndClient, WM_MDITILE, MDITILE_VERTICAL, 0
            ' // Cascade windows
            CASE IDM_CASCADE
               IF hwndClient THEN SendMessageW hwndClient, WM_MDICASCADE, 0, 0
            ' // Arrange icons
            CASE IDM_ARRANGE
               IF hwndClient THEN SendMessageW hwndClient, WM_MDIICONARRANGE, 0, 0
            CASE IDM_CLOSE
               ' // Close the active window
               IF hwndClient THEN
                  hwndActive = CAST(HANDLE, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))
                  IF SendMessageW(hwndActive, WM_QUERYENDSESSION, 0, 0) THEN
                     SendMessageW hwndClient, WM_MDIDESTROY, CAST(LPARAM, hwndActive), 0
            CASE IDM_CLOSEALL
               ' // Close all the MDI child windows
               IF hwndClient THEN
                  EnumChildWindows hwndClient, @CWindow_CloseEnumProc, 0
            ' // Exit the application
            CASE IDM_EXIT
         ' // Pass unprocessed messages to the active MDI child and then to DefFrameProc()
         hwndActive = CAST(HWND, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))
         IF IsWindow(hwndActive) THEN SendMessageW hwndActive, WM_COMMAND, wParam, lParam
      CASE WM_NOTIFY
         ptnmhdr = CAST(NMHDR PTR, lParam)
'         SELECT CASE ptnmhdr->idFrom
'         END SELECT
         IF hwndClient THEN
            IF IsWindow(hwndActive) THEN SendMessageW hwndActive, WM_NOTIFY, wParam, lParam
      CASE WM_SIZE
         ' // If the window isn't minimized, resize it
            IF hwndClient <> NULL AND pWindow <> NULL THEN
               pWindow->MoveWindow hwndClient, 0, 0, pWindow->ClientWidth + 2, pWindow->ClientHeight + 2, CTRUE
         ' // Note: This message is not passed to DefFrameProc when space
         ' // is being reserved in the client area of the MDI frame
         ' // or controls on the MDI frame are resizeable.
      CASE WM_CLOSE
         IF hwndClient THEN
            ' // Attempt to close all MDI child windows
            ' // If child windows are still open abort closing the application
            IF GetWindow(hwndClient, GW_CHILD) THEN EXIT FUNCTION
      CASE WM_QUERYENDSESSION
         IF hwndClient THEN
    CASE WM_DESTROY
         PostQuitMessage(0)
   IF hwndClient THEN
   ' // The DefFrameProc function provides default processing for any window
   ' // messages that the window procedure of a multiple-document interface (MDI)
   ' // frame window does not process. All window messages that are not explicitly
   ' // processed by the window procedure must be passed to the DefFrameProc
   ' // function, not the DefWindowProc function.
      FUNCTION = DefFrameProcW(hwnd, hwndClient, uMsg, wParam, lParam)
   ' // The DefWindowProc function calls the default window procedure to provide
   ' // default processing for any window messages that an application does not process.
   ' // This function ensures that every message is processed. DefWindowProc
   ' // is called with the same parameters received by the window procedure.
' Default CWindow MDI callback function.
   DIM hEdit AS HWND
   DIM rc AS RECT
   SELECT CASE uMsg
      CASE WM_CREATE
         DIM pWindow AS CWindow PTR = AfxCWindowPtr(GetAncestor(hwnd, GA_ROOTOWNER))
         ' // Create and edit control
         IF pWindow THEN
            GetClientRect hwnd, @rc
            pWindow->AddControl("Edit", hwnd, IDC_EDIT, "", 0, 0, rc.Right, rc.Bottom, _
               WS_CHILD OR WS_VISIBLE OR ES_MULTILINE OR WS_VSCROLL OR WS_HSCROLL OR ES_AUTOHSCROLL OR ES_AUTOVSCROLL OR ES_WANTRETURN OR ES_NOHIDESEL)
      CASE WM_MDIACTIVATE
         IF lParam = hwnd THEN
      CASE WM_SETFOCUS
         ' // Set the keyboard focus to the first control that is
         ' // visible, not disabled, and has the WS_TABSTOP style
         SetFocus GetNextDlgTabItem(hwnd, NULL, FALSE)
      CASE WM_SIZE
            ' // Resize the window and/or its controls
            hEdit = GetDlgItem(hwnd, IDC_EDIT)
            MoveWindow hEdit, 0, 0, LOWORD(lParam), HIWORD(lParam), CTRUE
         ' Don't exit. Let DefMDIChildProcW to process the message for
         ' properly resizing of the MDI child window.
      CASE WM_DESTROY
         ' // Do cleanup if needed, such removing properties attached
         ' // to the MDI child window.
   ' // The DefMDIChildProc function provides default processing for any window
   ' // message that the window procedure of a multiple-document interface (MDI)
   ' // child window does not process. A window message not processed by the window
   ' // procedure must be passed to the DefMDIChildProc function, not to the
   ' // DefWindowProc function.
   FUNCTION = DefMDIChildProcW(hwnd, uMsg, wParam, lParam)
I don't added support for MDI. It it obsolete and deprecated by Microsoft. Current applications use tabbed interfaces instead of MDI.
