Openfiledialog Customized
Started by docroger, December 28, 2025, 05:17:20 AM
docroger
Hello José,
Can you explain how i can get value of checkbox or combobox after i have selected a file in fileselector.
I can get the filename, but value of additional controls...
Thanx by advance...
To get the value of the checkbox and combobox in a custom IFileDialog dialog, you must do it within the OnFileOk event.
The interface does not allow you to obtain the text of the selected item in a combobox, but it does allow you to obtain the item ID that you assigned when adding it.
' CIFileDialogEventsImpl class
' Implementation of the FileDialogEvents callback interface
TYPE CIFileDialogEventsImpl EXTENDS CIFileDialogEvents
   DECLARE FUNCTION OnFileOk (BYVAL pfd AS IFileDialog PTR) AS HRESULT
END TYPE
PRIVATE FUNCTION CIFileDialogEventsImpl.OnFileOk (BYVAL pfd AS IFileDialog PTR) AS HRESULT
   ' // Initialize an instance of the CIFileDialogCustomize class
   DIM pCust AS CIFileDialogCustomize = pfd
   DIM bState AS BOOLEAN = pCust.GetCheckButtonState(1001)
   IF bState = TRUE THEN OutputDebugStringW("The checkbox is checked") ELSE OutputDebugStringW("The checkbox is unchecked")
   DIM item AS DWORD = pCust.GetSelectedControlItem(1002)
   OutputDebugStringW("Selected item: " & WSTR(item))
   RETURN S_OK
Full example:
' Microsoft Windows
' File: CW_CIOpenFileDialog_Customized_with_Events_01.bas
' Contents: Open/save file dialogs
' Copyright (c) 2025 José Roca. Freeware. Use at your own risk.
#define _WIN32_WINNT &h0602
#include once "AfxNova/CWindow.inc"
#include once "AfxNova/CIOpenSaveFile.inc"
#include once "AfxNova/CIFileDialogEvents.inc"
#include once "AfxNova/CIFileDialogCustomize.inc"
USING AfxNova
CONST IDC_TEST = 1001
   END wWinMain(GetModuleHandleW(NULL), NULL, wCommand(), SW_NORMAL)
' // Forward declaration
' Main
   ' // Set process DPI aware
   AfxEnableVisualStyles
   DIM pWindow AS CWindow
   DIM hWin AS HWND = pWindow.Create(NULL, "IOpenFile Dialog - Customized", @WndProc)
   pWindow.SetClientSize(800, 450)
   pWindow.Center
   ' // Add buttons
   pWindow.AddControl("Button", hWin, IDC_TEST, "&Test", pWindow.ClientWidth - 195, pWindow.ClientHeight - 35, 75, 23)
   pWindow.AddControl("Button", hWin, IDCANCEL, "&Close", pWindow.ClientWidth - 95, pWindow.ClientHeight - 35, 75, 23)
   ' // Anchor the controls
   pWindow.AnchorControl(IDC_TEST, AFX_ANCHOR_BOTTOM_RIGHT)
   pWindow.AnchorControl(IDCANCEL, AFX_ANCHOR_BOTTOM_RIGHT)
END TYPE
   RETURN S_OK
   STATIC hFocus AS HWND
   SELECT CASE uMsg
      CASE WM_NCACTIVATE
         ' // Save the handle of the control that has the focus
         IF wParam = 0 THEN hFocus = GetFocus
         ' // Note: Don't use EXIT FUNCTION
      CASE WM_SETFOCUS
         ' // Post a message to set the focus later, since some
         ' // Windows actions can steal it if we set it here
         IF hFocus THEN
            PostMessage hWnd, WM_USER + 999, cast(WPARAM, hFocus), 0
            hFocus = 0
      CASE WM_USER + 999
         ' // Set the focus
         IF wParam THEN SetFocus(cast(HWND, wParam))
      CASE WM_SYSCOMMAND
         ' // Capture this message and send a WM_CLOSE message
         IF (wParam AND &HFFF0) = SC_CLOSE THEN
            SendMessage hwnd, WM_CLOSE, 0, 0
      CASE WM_COMMAND
            CASE IDCANCEL
            ' // For testing purposes
            CASE IDC_TEST
               SCOPE
               DIM pofd AS CIOpenFileDialog
               ' // Set the file types
               pofd.AddFileType("FB code files", "*.bas;*.inc;*.bi")
               pofd.AddFileType("Executable files", "*.exe;*.dll")
               pofd.AddFileType("All files", "*.*")
               pofd.SetFileTypes()
               ' // Multiple selection (default is single selection)
               DIM options AS FILEOPENDIALOGOPTIONS = pofd.GetOptions
               pofd.SetOptions(options OR FOS_ALLOWMULTISELECT)
               ' // Optional: Set the title of the dialog
               '   pofd.SetTitle("A Single-Selection Dialog")
               ' // Set the folder
               pofd.SetFolder(CURDIR)
               pofd.SetDefaultExtension("bas")
               pofd.SetFileTypeIndex(1)
               ' // Customization
               ' // Get a pointer to the IFileDialog interface
               DIM pfdlg AS IFileDialog PTR = pofd.GetIFileDialogPtr
               IF pfdlg THEN
                  DIM pCust AS CIFileDialogCustomize = pfdlg
                  ' // Set events
                  DIM pfde AS ANY PTR = NEW CIFileDialogEventsImpl
                  pofd.SetEvents(pfde)
                  ' // Relese the IFileDialog interface
                  pfdlg->lpvtbl->Release(pfdlg)
                  ' // Add controls to the dialog
                  IF pCust.GetPtr THEN
                     ' Call methods of the CIFileDialogCustomize class
                     pCust.AddCheckButton(1001, "My check button", TRUE)
                     pCust.AddComboBox(1002)
                     pCust.AddControlItem(1002, 1, "First option")
                     pCust.AddControlItem(1002, 2, "Second optionn")
                     pCust.AddControlItem(1002, 3, "Third option")
                     pCust.AddEditBox(1003, "My edit control")
                     pCust.AddMenu(1004, "My menu")
                     pCust.AddPushButton(1005, "My push button")
                     pCust.AddSeparator(1006)
                     pCust.AddText(1007, "My text")
                     pCust.EnableOpenDropDown(1008)
               ' // Display the dialog
               DIM hr AS HRESULT = pofd.ShowOpen(hwnd)
               ' // Folder name
               OutputDebugStringW("Folder name: " & pofd.GetFolder)
               ' *** Single selection ***
               ' // Get the result
               IF hr = S_OK THEN
                  OutputDebugStringW(pofd.GetResultString)
               END SCOPE
    CASE WM_DESTROY
         PostQuitMessage(0)
docroger
Very nice as always !
Thanx José !
