AfxFilenameOriginalCase
Started by Paul Squires, January 05, 2026, 06:23:29 PM
Hi José,
I am sharing a new function (code below) that I wrote the other day. There are times when you have a full path filename in some type of letter casing but you want to interact with that filename in its original casing per the way it is stored in Windows.
For example, I am integrating the GDB Debugger into Tiko and GDB returns filenames back to Tiko in UPPERCASE format. Sure, I could use that uppercase file and display it in uppercase but visually it looks much more pleasing for the filename to display within the Tiko Editor using the original case.
A filename like:
C:\DEV\TIKO_EDITOR_DEBUGGER\DEBUG-EXAMPLE\TESTFILE2.BAS
Gets converted to:
C:\dev\tiko_editor_debugger\Debug-Example\TestFile2.bas
This code might be interesting to add to AfxNova if you also find it worthwhile.
' Get the original case filename as stored by Windows
function AfxFilenameOriginalCase( byval filename as DWSTRING ) as DWSTRING
    dim as long bufSize = 1024
    dim as DWSTRING buffer = wspace(bufSize \ 2)
    dim as HANDLE hfile = CreateFileW(filename, GENERIC_READ, FILE_SHARE_READ, _
                                null, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, null)
    if hfile = INVALID_HANDLE_VALUE then exit function
    dim as DWORD result = GetFinalPathNameByHandleW( hfile, *buffer, bufSize, FILE_NAME_NORMALIZED )
    if (result > 0) andalso (result < bufSize) then
        ' Good data returned but still need to remove the mapping characters
        if left(buffer, 4) = "\\?\" then buffer = mid(buffer, 5)
    else
        ' error: could not retrieve path.
    ' clean up
    CloseHandle(hfile)
    function = buffer
end function
I didn't forget about the function you proposed earlier.
The reason I didn't implement it immediately is that something important was missing, and I needed to study the official documentation for GetFinalPathNameByHandleW first.
According to Microsoft's documentation , the function's return value is the length of the string in TCHARs, excluding the terminating null character. This detail affects how the buffer must be allocated and how the result must be trimmed. Without understanding this behavior precisely, the function could return incorrect or partially truncated paths, especially when dealing with long filenames or UNC paths.
Once I reviewed the documentation carefully, I was able to implement a correct and robust version:
- dynamic buffer resizing based on the exact size required
- proper handling of the \\?\ and \\?\UNC\ prefixes
- correct trimming of the returned string
- support for both files and directories
and a variant that accepts a HANDLE directly
So the delay wasn't because I forgot your suggestion — I simply needed to confirm how the API behaves internally before finalizing the implementation.
Thanks again for the original idea. It was a good starting point, and now the function works reliably in all cases.
I have added them to fbxWin.inc, using USTRING and DEFER.
' Returns the original-case filename as stored by Windows.
' Uses GetFinalPathNameByHandleW with dynamic buffer, UNC handling,
' directory support, and automatic cleanup via DEFER.
FUNCTION fbxGetFilenameOriginalCase OVERLOAD (BYREF wszFileName AS WSTRING) AS USTRING
   DIM INITIAL_SIZE AS LONG = 1024
   DIM hFile AS HANDLE
   DIM dwNeeded AS DWORD
   DIM dwFlags AS DWORD = FILE_NAME_OPENED
   DIM ustrResult AS USTRING = WSPACE(INITIAL_SIZE \ 2)
   ' Open file or directory
   hFile = CreateFileW(wszFileName, GENERIC_READ, _
                       FILE_SHARE_READ OR FILE_SHARE_WRITE OR FILE_SHARE_DELETE, _
                       NULL, OPEN_EXISTING, _
                       FILE_ATTRIBUTE_NORMAL OR FILE_FLAG_BACKUP_SEMANTICS, _
                       NULL)
   IF hFile = INVALID_HANDLE_VALUE THEN RETURN ""
   ' Automatic cleanup
   DEFER CloseHandle(hFile)
   ' First call: get required size
   dwNeeded = GetFinalPathNameByHandleW(hFile, STRPTR(ustrResult), INITIAL_SIZE, dwFlags)
   IF dwNeeded = 0 THEN RETURN ""
   ' Resize buffer if needed
   IF dwNeeded >= INITIAL_SIZE THEN
      ustrResult = WSPACE(dwNeeded + 1)
      dwNeeded = GetFinalPathNameByHandleW(hFile, STRPTR(ustrResult), dwNeeded + 1, dwFlags)
   ' Trim to actual length (dwNeeded does not include the null terminator)
   ustrResult = LEFT(ustrResult, dwNeeded)
   ' Remove \\?\ prefix
   IF LEFT(ustrResult, 4) = $"\\?\" THEN
      ustrResult = MID(ustrResult, 5)
   ELSEIF LEFT(ustrResult, 7) = $"\\?\UNC\" THEN
      ustrResult = $"\\" & MID(ustrResult, 7)
   RETURN ustrResult
' Returns the original-case filename associated with a HANDLE.
' The HANDLE must refer to a file or directory opened with sufficient access rights.
FUNCTION fbxGetFilenameOriginalCaseFromHandle OVERLOAD (BYVAL hFile AS HANDLE) AS USTRING
   ' Validate handle
   IF hFile = INVALID_HANDLE_VALUE OR hFile = NULL THEN RETURN ""
      ' dwNeeded = number of characters without the terminating null
   RETURN ustrResult
Excellent - thanks José, appreciate it!
Pierre Bellisle
Hey guys !
  'This part will never be reached because the first [IF] will be triggered
#4
Thanks, Pierre—long time no see!
This feature was included in fbx, a framework for FBC-Modern, but it no longer exists because that project eventually evolved into tiko-lang.
https://tiko-lang.net/
Pierre Bellisle
¡Hola, José!
¡Hace mucho que no nos vemos, de verdad! (Long time no see indeed!)
In fact, I've end up here reading Tiko stuff...
Seems Paul dit it again!
And having you as a accomplice is nothing but good news.
I guess I will read a little more about the new kid in town,
I already saw many great things,
not to say about the LLVM choice, which is a pretty nice one in my humble opinion.
cu
#6
There is a lot to read: thousands of pages and two books. Some of the new features have already become indispensable to me.
My AfxNova framework for FreeBasic was very large because it sought to compensate for FreeBasic's shortcomings regarding Unicode, math, string manipulation, file handling, etc.
All of that is now incorporated into tiko-lang, so my library for Windows will focus on APIs that exist only on Windows, e.g. GDI+, RichEdit, WebView2, Direct2D, COM, etc.
I hope this can be useful for programmers like me who work exclusively with Windows.
Pierre Bellisle
To be honest, as you may already know, my fondness for FB wasen't eternal.
Too many of this, not enough of that...
Pre-looking at Tiko compiler, I think that many of the little things I personnally have trouble with in FB are things of the past. Not to say that the evolution of the FB language is quite slow, exepting for the effort of two certain guys, of course...
This fresh wind is welcome.
The dynamic strings managment looks great, I've always thought that this was at the eart of any BASIC language. It dosen't look like my beloved bstr are there, look alike Ustring is another things that I will have to check. I guess thinking multi platform have some exigences or maybe there are other advantage that I'm not aware of. More stuff to think about...
The embedded functions list is impressive. Like in many language, some looks like simple api call but they are well choosen and I'm sure majority will find usefull, it may act also as a memory refresher of what is avaiable for api lovers.
For your framework, if I understand well, I do not have to look anywhere else than in Tiko folder. Simple is beautiful.
If I may ask, you know how curious I am, as an apetizer, can you tell some of new features that are now indispensable to you?
