Gdiplus examples
Started by Frank Bruebach, January 14, 2026, 02:10:44 PM
Frank Bruebach
hello jose, I wanted to test some of your gdiplus examples.
for example: "Gdip_BeginContainer.bas." I have downloaded your last update of afxnova,
but I have got some problems with a lot of doublicated definition in "dwstring.bi"
and "bstring.inc" perhaps there are some more, I don't know. I suppose it's only a little problem to fix this one.
' Microsoft Windows
' File: Gdip_BeginContainer.bas
' Contents: GDI+ Flat API - GdipBeginContainer example
' Copyright (c) 2026 José Roca. Freeware. Use at your own risk.
#define _WIN32_WINNT &h0602
'#define _GDIP_DEBUG_ 1
#INCLUDE ONCE "AfxNova/AfxGdipObjects.inc"
#INCLUDE ONCE "AfxNova/CGraphCtx.inc"
USING AfxNova
CONST IDC_GRCTX = 1001
   END wWinMain(GetModuleHandleW(NULL), NULL, wCOMMAND(), SW_NORMAL)
' // Forward declaration
' This example demonstrates how to use GdipBeginContainer and GdipEndContainer
' to isolate transformations and rendering settings within a scoped graphics container.
SUB Example_BeginContainer (BYVAL hdc AS HDC)
   ' // Create a graphics object from the device context
   DIM graphics AS GdiPlusGraphics = hdc
   ' // Set the scale transform
   graphics.ScaleTransform
   ' // Draw a base rectangle (no transformation)
   DIM basePen AS GdiPlusPen = GdiPlusPen(ARGB_BLACK, 2.0)
   GdipDrawRectangle(graphics, basePen, 20, 20, 100, 50)
   ' // Begin container
   DIM container AS GraphicsContainer
   GdipBeginContainer2(graphics, @container)
   ' // Apply transformation inside container
   GdipTranslateWorldTransform(graphics, 150, 0, MatrixOrderPrepend)
   GdipRotateWorldTransform(graphics, 30.0, MatrixOrderAppend)
   ' // Draw transformed rectangle
   DIM redPen AS GdiPlusPen = GdiPlusPen(ARGB_RED, 2.0)
   GdipDrawRectangle(graphics, redPen, 20, 20, 100, 50)
   ' // End container (restores previous state)
   GdipEndContainer(graphics, container)
   ' // Draw another rectangle (back to original state)
   DIM bluePen AS GdiPlusPen = GdiPlusPen(ARGB_BLUE, 2.0)
   GdipDrawRectangle(graphics, bluePen, 20, 90, 100, 50)
' Main
   ' // Set process DPI aware
   AfxEnableVisualStyles
   ' // Create the main window
   DIM pWindow AS CWindow = "MyClassName"
   pWindow.Create(NULL, "GDI+ GdipBeginContainer", @WndProc)
   ' // Size it by setting the wanted width and height of its client area
   pWindow.SetClientSize(400, 250)
   ' // Center the window
   pWindow.Center
   ' // Add a graphic control
   pGraphCtx.Clear RGB_WHITE
   ' // Anchor the control
   pWindow.AnchorControl(pGraphCtx.hWindow, AFX_ANCHOR_HEIGHT_WIDTH)
   ' // Get the memory device context of the graphic control
   DIM hdc AS HDC = pGraphCtx.GetMemDc
   ' // Initialize GDI+
   DIM token AS ULONG_PTR = AfxGdipInit
   ' // Draw the graphics
   Example_BeginContainer(hdc)
   ' // Shutdown GDI+
   AfxGdipShutdown token
' Main window procedure
   SELECT CASE uMsg
      ' // If an application processes this message, it should return zero to continue
      ' // creation of the window. If the application returns –1, the window is destroyed
      ' // and the CreateWindowExW function returns a NULL handle.
      CASE WM_CREATE
         AfxEnableDarkModeForWindow(hwnd)
         RETURN 0
      ' // Theme has changed
      CASE WM_THEMECHANGED
         RETURN 0
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN
                  RETURN 0
    CASE WM_DESTROY
         PostQuitMessage(0)
         RETURN 0
#1
I'm not getting any error. Check the path in the Compiler Setup.
Also wait until I will finish the work. AfxGdipObjects.inc has changed. Reupload it.
