Trackbar question & animate window
Started by Frank Bruebach, Today at 02:24:00 PM
Frank Bruebach
hello. I have tried yesterday just for fun to use the slider (trackbar) control.
I couldn't find Trackbar_SetTicfreq hTrackBar, 10 ', 0 ' function, that doesnt exist in cWindow?
I have built and add in cWindow 'SendMessageW hTrackBar, TBM_SETTICFREQ, 10,0' but this code have no effect in my current example.
how to insert a correct AnimateWindow() effect fade in fade out using the slider control  ?
my code I have built so far..
thanks, frank
' trackbar example
#define UNICODE
#INCLUDE ONCE "AfxNova/CWindow.inc"
USING AfxNova
' Constants for animation types
const AW_HOR_POSITIVE = 1
Const AW_HOR_NEGATIVE = 2
Const AW_VER_POSITIVE = 4
Const AW_VER_NEGATIVE = 8
Const AW_CENTER = 16
Const AW_SLIDE = 262144
Const AW_BLEND = 524288
   END wWinMain(GetModuleHandleW(NULL), NULL, wCommand(), SW_NORMAL)
' // Forward declaration
CONST IDC_TRACKBAR = 1001
' Main
   ' // Set process DPI aware
   AfxEnableVisualStyles
   ' // Creates the main window
   DIM pWindow AS CWindow = "MyClassName"   ' Use the name you wish
   DIM hWin AS HWND = pWindow.Create(NULL, "CWindow - TrackBar", @WndProc)
   pWindow.SetClientSize(400, 220)
   ' // Centers the window
   pWindow.Center
   ' // Adds a Trackbar control
   DIM hTrackBar AS HWND = pWindow.AddControl("Trackbar", hWin, IDC_TRACKBAR, "", 75, 60, 240, 32)
   ' // Set the range values
   Trackbar_SetRangeMin hTrackBar, 0, TRUE
   Trackbar_SetRangeMax hTrackBar, 20, TRUE
   ' new
   Trackbar_SetTicfreq hTrackBar, 10 ', 0 ' doesnt exist ?
   ' SendMessageW hTrackBar, TBM_SETTICFREQ, 10,0 ' included in cWindow ?
   ' // Set the page size
   Trackbar_SetPageSize hTrackBar, 1
   pWindow.AnchorControl(IDC_TRACKBAR, AFX_ANCHOR_WIDTH)
' Fade the window in over 500 milliseconds
    AnimateWindow(hWin, 500, AW_BLEND Or AW_ACTIVATE)
    Sleep 2000 ' Wait for 2 seconds
    ' Slide the window out to the right
     AnimateWindow(hWin, 500, AW_SLIDE Or AW_HOR_POSITIVE Or AW_HIDE)
   ' // Adds a button
   pWindow.AddControl("Button", hWin, IDCANCEL, "&Close", 270, 155, 75, 30)
   ' // Anchors the button to the bottom and the right side of the main window
   pWindow.AnchorControl(IDCANCEL, AFX_ANCHOR_BOTTOM_RIGHT)
' Main window procedure
   SELECT CASE uMsg
      ' // If an application processes this message, it should return zero to continue
      ' // creation of the window. If the application returns –1, the window is destroyed
      ' // and the CreateWindowExW function returns a NULL handle.
      CASE WM_CREATE
         RETURN 0
      ' // Sent when the user selects a command item from a menu, when a control sends a
      ' // notification message to its parent window, or when an accelerator keystroke is translated.
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN SendMessageW(hwnd, WM_CLOSE, 0, 0)
         RETURN 0
      CASE WM_HSCROLL
         IF GetWindowID(cast(HWND, lParam)) = IDC_TRACKBAR THEN
            ' Put your code here
            ' The LOWORD of wParam specifies a scroll bar value that indicates the user's scrolling request.
            ' The HIWORD specifies the current position of the scroll box if the LOWORD is SB_THUMBPOSITION
            ' or SB_THUMBTRACK; otherwise, this word is not used.
            'AnimateWindow(hwnd, 500, AW_BLEND Or AW_ACTIVATE)
         RETURN 0
      CASE WM_DESTROY
         PostQuitMessage(0)
         RETURN 0
Frank Bruebach
#1
Update: Slider fade Out at Position 20 works. Only the setticfreq marks are still Missing.. better to say the Marks (Labels) below trackbar control
 slider fade out at position 20 go
#define UNICODE
USING AfxNova
Const AW_HIDE  = 65536
Const AW_ACTIVATE = 131072
Const AW_HOR_POSITIVE = 1
Const IDC_TRACKBAR = 1001
FUNCTION wWinMain(hInstance AS HINSTANCE, hPrevInstance AS HINSTANCE, _
                  pwszCmdLine AS WSTRING PTR, nCmdShow AS LONG) AS LONG
    DIM win AS CWindow = "MyClassName"
    DIM hWin AS HWND = win.Create(NULL, "Trackbar + AnimateWindow", @WndProc)
    win.SetClientSize(400, 220)
    win.Center
    ' Trackbar mit Ticks
    DIM hTrack AS HWND = win.AddControl("Trackbar", hWin, IDC_TRACKBAR, "", _
                                        75, 60, 240, 32, _
                                        WS_CHILD OR WS_VISIBLE OR TBS_AUTOTICKS)
    Trackbar_SetRangeMin(hTrack, 0, TRUE)
    Trackbar_SetRangeMax(hTrack, 20, TRUE)
    Trackbar_SetTicfreq hTrack, 10 ' doesnt exist ?
    ' Jetzt funktioniert es
    SendMessageW(hTrack, TBM_SETTICFREQ, 5, 0)
    win.AddControl("Button", hWin, IDCANCEL, "&Close", 270, 155, 75, 30)
    win.AnchorControl(IDCANCEL, AFX_ANCHOR_BOTTOM_RIGHT)
    FUNCTION = win.DoEvents(nCmdShow)
FUNCTION WndProc(hwnd AS HWND, uMsg AS UINT, wParam AS WPARAM, lParam AS LPARAM) AS LRESULT
    SELECT CASE uMsg
    CASE WM_SHOWWINDOW
       ' IF GetWindowID(cast(HWND, lParam)) = IDC_TRACKBAR THEN
        'IF wParam = TRUE THEN
            ' Fade-In
            AnimateWindow(hwnd, 500, AW_BLEND OR AW_ACTIVATE)
        RETURN 0
    CASE WM_HSCROLL
        IF GetWindowID(CAST(HWND, lParam)) = IDC_TRACKBAR THEN
            DIM posy AS LONG = Trackbar_GetPos(CAST(HWND, lParam))
            ' Fade-Out abhängig vom Slider
            IF posy = 20 THEN
                AnimateWindow(hwnd, 500, AW_BLEND OR AW_HIDE)
        RETURN 0
    CASE WM_COMMAND
        IF CBCTL(wParam, lParam) = IDCANCEL THEN
        RETURN 0
    CASE WM_DESTROY
        PostQuitMessage(0)
        RETURN 0
    RETURN DefWindowProcW(hwnd, uMsg, wParam, lParam)
Frank Bruebach
Another example with transparency of Main Window works fine by using trackbar Control
' slider window transparency works :-)
#define UNICODE
USING AfxNova
    DIM win AS CWindow = "LayeredWindow"
    DIM hWin AS HWND = win.Create(NULL, "Slider Transparency", @WndProc)
    ' Fenstergröße
    win.Center
    ' Fenster zu einem Layered Window machen
    DIM exStyles AS LONG = GetWindowLongW(hWin, GWL_EXSTYLE)
    SetWindowLongW(hWin, GWL_EXSTYLE, exStyles OR WS_EX_LAYERED)
    ' Anfangstransparenz (255 = voll sichtbar)
    SetLayeredWindowAttributes(hWin, 0, 255, LWA_ALPHA)
    ' Trackbar
                                        75, 60, 240, 32, _
    Trackbar_SetRangeMax(hTrack, 255, TRUE)
    SendMessageW(hTrack, TBM_SETTICFREQ, 25, 0)
    ' Close Button
    SELECT CASE uMsg
    CASE WM_HSCROLL
            ' Transparenz setzen
            ' posy = 0   → komplett durchsichtig
            ' posy = 255 → komplett sichtbar
            SetLayeredWindowAttributes(hwnd, 0, posy, LWA_ALPHA)
        RETURN 0
    CASE WM_COMMAND
        RETURN 0
    CASE WM_DESTROY
        PostQuitMessage(0)
        RETURN 0
'ends
