Egrid32 / Egrid32 Form Upgrade
Started by Elias Montoya, October 15, 2004, 12:42:14 AM
Elias Montoya
Egrid32 has been upgraded to version 3.06.06
New in this upgrade
1.- Keyboard shortcuts improved.
2.- Keyboard handling of egrid was improved. Readonly cells support
for delete key and controls.
3.- Sorting feature now supports checkbox state sorting. It was also improved to support indexing (for use with imagelists). The parameter @EGN.Index now contains the virtual row that contains the info under full line mode.
4.- improvement on speed for redrawing and loading.
5.- Fix: GPF when moving arrow right when the last and first columns where visible.
6.- Creation parameter support. 39 parameters to configure Egrid at creation or at run time. (See Egrid Creation topic in the help file)
7.- Update of the VB headers, VB now supports the latest features of Egrid32.
8.- Update of the phoenix declarations for properties and notifications.
9.- Support for readonly columns.
10.- Added EZ_SetEgridSize to the wrappers. It allows to change the grid size at run time.
11.- Help file was also updated.
If you want to see a sample of Egrid32 Sorting clic this link:
www.sweetheartgames.com/SortingDemo.zip
The form designer was also upgraded to version 1.05
1.- Fix: GPF Fix when generating code.
2.- Progress indicators for saving and loading.
